    Sensor not working problem
    Filament Monitor
    • Thaliosundefined
      Thalios
      Hello!
      I'm having a weird issue.
      Was printing and for some reason, had some extruder issues (something mechanical i need to easily solve, i think i was printing too fast).
      My filament monitor (laser v2) gave me a typical movement to low, and paused. After a few tweaks, I got it to extrude properly (slowed down and decreased extrusion). The monitor still freaked though. M591 D0 gave me 99 to 104% reading, but still stopped...
      Then after a few resume commands, I got a message saying Extruder 0 sensor not working.
      Here's the weird part. I disabled it (M591 D0 S0) and it still gives me that same message and pauses the print.
      Shouldn't the sensor be ignored when I give it that command?
      M122:
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
      Board ID: 08DJM-956L2-G43S4-6J9D0-3SD6Q-9U5GF
      Used output buffers: 1 of 40 (30 max)
      Static ram: 154604
      Dynamic ram: 163148 of which 220 recycled
      Exception stack ram used: 560
      Never used ram: 74684
      Tasks: NETWORK(ready,228) ETHERNET(blocked,408) HEAT(blocked,1088) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1424) TMC(blocked,60) MAIN(running,4472) IDLE(ready,76)
      Owned mutexes:
      Last reset 04:35:16 ago, cause: software
      Last software reset at 2020-05-27 22:01, reason: User, spinning module GCodes, available RAM 74884 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 47.5, current 47.7, max 49.1
      Supply voltage: min 24.0, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
      Driver 0: standstill, reads 12775, writes 4 timeouts 0, SG min/max 0/231
      Driver 1: standstill, reads 12775, writes 4 timeouts 0, SG min/max 0/121
      Driver 2: standstill, reads 12774, writes 4 timeouts 0, SG min/max 0/0
      Driver 3: standstill, reads 12775, writes 4 timeouts 0, SG min/max 0/321
      Driver 4: standstill, reads 12779, writes 0 timeouts 0, SG min/max not available
      Driver 5: standstill, reads 12779, writes 0 timeouts 0, SG min/max not available
      Date/time: 2020-05-28 02:36:48
      Slowest loop: 16.29ms; fastest: 0.21ms
      === Storage ===
      Free file entries: 9
      SD card 0 detected, interface speed: 25.0MBytes/sec
      SD card longest read time 3.7ms, write time 0.9ms, max retries 0
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 348, MaxWait: 118167ms
      === MainDDARing ===
      Scheduled moves: 32162, completed moves: 32162, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      Heater 0 is on, I-accum = 0.3
      Heater 1 is on, I-accum = 0.4
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 7.72ms; fastest: 0.03ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 2 of 8
      - Ethernet -
      State: active
      Error counts: 0 0 0 0 0
      Socket states: 2 2 2 2 2 0 0 0
      === Filament sensors ===
      Extruder 0: pos 0.75, errs: frame 15 parity 0 ovrun 0 pol 9 ovdue 0
      === CAN ===
      Messages sent 5569, longest wait 0ms for type 0
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 16516854ms ago
      RX/TX seq numbers: 0/1
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 0/0-0
      config.g
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Apr 29 2020 20:50:30 GMT-0400 (EDT)
      M550 P"Ender 3 Pro"                                ; set printer name
      M918 P1 E4 F2000000                                ; configure direct-connect display
      M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
      M569 P0.0 S1 D3                                    ; physical drive 0.0 goes forwards
      M569 P0.1 S1 D3                                    ; physical drive 0.1 goes forwards
      M569 P0.2 S0 D3                                    ; physical drive 0.2 goes backwards
      M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E141.32                  ; set steps per mm
      M566 X1200.00 Y1200.00 Z48.00 E1200.00             ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z250.00 E6000.00            ; set maximum speeds (mm/min)
      M201 X300.00 Y300.00 Z200.00 E6000.00              ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
      M208 X245 Y225 Z230 S0                             ; set axis maxima
      M574 X1 S1 P"io0.in"                               ; configure active-high endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in"                               ; configure active-high endstop for low end on Y via pin io1.in
      M574 Z1 S2			                               ; configure to use z-probe
      M558 P1 C"io6.in+io6.out" H2.5 F100 T9000          ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X-22 Y4 Z1.30                             ; set Z probe trigger value, offset and trigger height
      M557 X30:195 Y25:200 P5                            ; define mesh grid
      M308 S0 P"temp1" Y"thermistor" T100000 B4092       ; configure sensor 0 as thermistor on pin temp1
      M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp0" Y"thermistor" T100000 B4092       ; configure sensor 1 as thermistor on pin temp0
      M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
      M143 H1 S270                                       ; set temperature limit for heater 1 to 270C
      M950 F0 C"out8" Q500                               ; create fan 0 on pin out8 and set its frequency
      M106 P0 S1 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"!out4" Q25000                             ; create fan 1 on pin out4 and set its frequency
      M106 P1 S1 H1 T45								   ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"!out6" Q25000							   ; create fan 2 on pin out6 and set its frequency
      M106 P2 S1 H1 T20                                  ; set fan 2 value. Thermostatic control is turned on
      M563 P0 D0 H1 F-1                                  ; define tool 0
      G10 P0 X-5 Y0 Z0                                   ; set tool 0 axis offsets
      ; Custom settings
      M591 D0 P5 C"io3.in" R15:130 E3 S1 A0              ; Enable and set Filament monitor
      T0                                                 ; select first tool
      M572 D0 S0.2									   ; pressure advance setting
      M501                                               ; Load config overrides
      Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
      Heavily modified Ender 3 Pro (Duet 3 6HC)
      Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
      CR-10S Pro V2 (Duet 3 Mini 5+)
      and a bunch of SLA printers..
        dc42 administrators @Thalios
        @Thalios said in Sensor not working problem:
        Yes, it should. After you send that command, if you send M591 D0 what is the response?
        • Thaliosundefined
          Thalios
          M591:
          M591 d0
          Duet3D laser filament monitor v2 on pin io3.in, disabled, allow 15% to 130%, check every 3.0mm, version 2, quality 224, brightness 117, shutter 79, measured min 88% avg 98% max 111% over 161.5mm
