SOLVED Trying to update RRF3 to DUET 2
trying to update my duet 2 wifi to RRF3 but only the DWC updates.
im sending M115 to confirm but this is what I get:M115 FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-02-09b1
any thoughts?
are you trying to go directly to RRF 3.1.1?
If so, you need to install RRF 3.0 stable first and then 3.1.1
presumably you read
https://github.com/Duet3D/RepRapFirmware/releases
Users of RepRapFirmware 2.x cannot upgrade directly to this release because the binaries for the Duet 2 series are too large for the Duet 2 IAP programs. So you must upgrade to RepRapFirmware 3.0 first, then you can upgrade immediately to version 3.1.1. Alternatively, you can use Bossa over USB to upgrade directly to RepRapFirmware 3.1.1 but in this case you will need to upload DWC 3.1.1 and the appropriate IAP file separately.
YES!
My bad!
it works....thanks
