SOLVED Duet 2 WiFi error: unknown temperature sensor channel
Hi all,
This is my first post to the forum, as I have generally been able to use your advice to resolve my many issues with the Duet so far.
The latest in my long series of problems happened yesterday, and I dont know how to resolve it. I had finally managed to get my motors at least moving, and decided to add my extruder (which I had working previously). When I set the extruder to heat I got the message "Error: Temperature reading fault on heater 1: unknown temperature sensor channel" and the current temp was reading as 2000.0 C. I captured a screenshot below.
I have tried different thermistors and heaters, and have also tried the different heater ports etc, but no joy.
Below is a sanitized copy of my config.g file (if it helps):
; generated by RepRapFirmware Configuration Tool v3.1.1 on Mon Jun 01 2020 18:34:28 GMT+0100 (British Summer Time); General preferences
M550 P"*****" ; set printer name; Network
M551 P"*****" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P2 S0 ; physical drive 2 goes forwards
M92 X80.00 Y80.00 Z4000.00 E837.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z250.00 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X230 Y210 Z200 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M575 P1 B57600 S1 ;Set paneldue baud rate (57600)
I really am hoping someone can help me as I am fast approaching the end of my patientlce with this board. I don't mind a learning curve, but I just seem to keep going from one problem to the next. I even had to do some troubleshooting to join the forum and make this post 😊
I look forward to hearing from you!
How do you have things currently connected to the board?
Your config.g looks ok provided you're actually using RRF3. Can you send M115 in the console to see the currently installed firmware version?
Thanks for responding!
After reading your post I ran M115 and found something quite interesting. Yesterday, I upgraded the Duet to firmware 3.1.1, or so I thought; running M115 I can see that the firmware is actually 2.05.1:
I also noticed my Paneldue was showing the following after I tried to upgrade to 3.1.1 again today:
The upgrade hasn't worked, and I am confused about the paneldue constantly showing 'Connecting'...
Do I need to reset the board or do something differently?
Also, forgive the mess, but this is the current wiring state (i have removed endstops to make the picture clearer):
@Harrynice Upgrade to RepRapFirmware 3.0 first, then to 3.1.1. Due to the size of the firmware, the in-app-programmer (IAP - which writes the new firmware over the old firmware while the board is running) needs to be updated by doing this intermediate step. This is also explained in the update notes (See "Upgrading to this release from RepRapFirmware 2.x" here https://github.com/Duet3D/RepRapFirmware/releases/tag/3.1.1 ) :
Users of RepRapFirmware 2.x cannot upgrade directly to this release because the binaries for the Duet 2 series are too large for the Duet 2 IAP programs. So you must upgrade to RepRapFirmware 3.0 first, then you can upgrade immediately to version 3.1.1. Alternatively, you can use Bossa over USB to upgrade directly to RepRapFirmware 3.1.1 but in this case you will need to upload DWC 3.1.1 and the appropriate IAP file separately.
RepRapFirmware 3.0 is here: https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0
You should be able to upgrade just by uploading file Duet2and3Firmware-3.0.zip into /sys on the SD card via Duet Web Control, then do the same again (after it's updated) with 3.1.1.Ian
Amazing! It is now working again! Thank you so much for pointing this out - I could have sworn I did the upgrade to 3.0.0 first, but apparently not!
Looks like PEBKAC and issue now appears to be solved, so please accept a virtual beer from me :).
