Error while building reprap firmware 3
Hi @dc42 I'm trying to compile reprap firmware 3 for my duet3 board.
I've donwloaded branches and using build configuration as given below.RepRapFirmware: v3-dev - Duet3_V06 CoreNG: dev - SAME70 FreeRTOS: master - SAME70 RRFLibraries: dev - SAME70_RTOS DuetWiFiSocketServer: master CANlib : master - SAME70
but getting error as shown in screenshot.
I've not made any changes in code.
You need to roll back project RRFLibraries to the 3.1.0 tag, https://github.com/Duet3D/RRFLibraries/releases.
That worked but now getting other linker errors. Multiple definition in networking.
one of them is given below.
Description Resource Path Location Type
./src/Networking/LwipEthernet/Lwip/out/build/x64-Debug/CMakeFiles/3.16.19112601-MSVC_2/CompilerIdC/CMakeCCompilerId.o:(.data.info_arch+0x0): multiple definition of `info_arch'; ./src/Networking/LwipEthernet/Lwip/out/build/x64-Debug/CMakeFiles/3.16.19112601-MSVC_2/CompilerIdCXX/CMakeCXXCompilerId.o:(.data.info_arch+0x0): first defined here RepRapFirmware -
The symbol "info_arch" is not used anywhere in RepRapFirmware. I see references to MSVC and X64-debug in your listing. Have you by any chance compiled the files using MSVC instead of gcc?
@dc42 I was trying to add project in vscode. It was taking too much time create Makefile so left it in half. Thank you for the help Sir.
