Temporary failure resolving 'pkg.duet3d.com'
I am having issues upgrading my SBC Pi4 with a Duet3.
pi@duet3:~ $ sudo apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:2 http://archive.raspberrypi.org/debian buster InRelease Err:3 https://pkg.duet3d.com unstable InRelease Temporary failure resolving 'pkg.duet3d.com' Err:4 https://pkg.duet3d.com stable InRelease Temporary failure resolving 'pkg.duet3d.com' Reading package lists... Done W: Failed to fetch https://pkg.duet3d.com/dists/unstable/InRelease Temporary failure resolving 'pkg.duet3d.com' W: Failed to fetch https://pkg.duet3d.com/dists/stable/InRelease Temporary failure resolving 'pkg.duet3d.com' W: Some index files failed to download. They have been ignored, or old ones used instead. pi@duet3:~ $
I don't know if it is a DNS issue on my end or if something is down.
Thanks!
Its working again. Consider it solved.
Thanks!
same problem today...
It may be a server connectivity issue. I've noticed some errors trying to access the forum as well. Give it a try again later.
@RobMink said in Temporary failure resolving 'pkg.duet3d.com':
dns resolving is usually on "your" end, you could try f.ex.
dig
to resolve with google or opendns something like:dig pkg.duet3d.com @8.8.8.8
ordig pkg.duet3d.com @208.67.222.123
that'll bypass your local and your isp dns (unless there are firewall rules redirecting dns traffic)
'dig' isn't included in the duet raspian distro. It can be installed via "sudo apt install dnsutils"
