    2.05.1 restart issues
    Firmware installation
    • DennisF
      DennisF last edited by DennisF
      Hi all,
      I've recently updated from 2.02 to 2.05.1 on a Duet Wifi+Duex5. (See M122 below).
      With that upgrade I've started having issues with the restart of the board. Very often when I do a stop (mechanical button, web, or panel) the board fails to boot it's user interfaces again. With that I mean that it comes back to load it's config.c (fans start at programmed rate) and it connects to wifi and is pingable but both the web gui and the 7" control panel stop receiving data/update and do not allow interaction with the device.
      A quick power off/on doesn't help. I need a long power off (>20 seconds; to drain all caps I suppose) before it loads the UI's again.
      Is that a known thing? Didn't find much on it.
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
      Board ID: 08DGM-9T6BU-FG3S4-6J1D8-3S86Q-1BRHF
      Used output buffers: 3 of 24 (9 max)
      Static ram: 25712
      Dynamic ram: 93948 of which 116 recycled
      Exception stack ram used: 320
      Never used ram: 10976
      Tasks: NETWORK(ready,744) HEAT(blocked,1176) DUEX(suspended,160) MAIN(running,3760) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:26:40 ago, cause: power up
      Last software reset at 2020-06-10 21:52, reason: User, spinning module GCodes, available RAM 10640 bytes (slot 2)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 17.7, current 22.0, max 22.3
      Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 5: standstill, SG min/max not available
      Driver 6: standstill, SG min/max not available
      Driver 7: standstill, SG min/max not available
      Driver 8: standstill, SG min/max not available
      Driver 9: standstill, SG min/max not available
      Date/time: 2020-06-11 09:00:26
      Slowest loop: 5.63ms; fastest: 0.07ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 25.92ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.23
        WiFi MAC address cc:50:e3:15:1a:a4
        WiFi Vcc 3.35, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 25672
        WiFi IP address 192.168.5.95
        WiFi signal strength -58dBm, reconnections 0, sleep mode modem
      JoergS5 1 Reply Last reply Reply Quote 0
      • JoergS5
        JoergS5 @DennisF last edited by JoergS5
        @DennisF The only idea I have is that if you reboot a short time, maybe the Wifi WLAN sessions survive and addup until you don't have enough available sessions available to access with browser or PanelDue, so you could watch whether the "HTTP sessions 1 of 8" of M122 is going up when you experience the problem, or other problems in the WiFi section of M122. Another possibility are other internet connections to Duet which eat up the connections before you try to access with the browser (e.g. monitoring tools).
        • DennisF
          Hi @JoergS5, thanks for the reply.
          I'm quite convinced the board reboots. Everything shuts down for a little bit; fans, heating, power, lights and also the IP stack as it's unpingable for a few seconds. Still this might be interesting to look at, need to figure out how to debug this thing while it dies...
            dc42 administrators @DennisF last edited by
            @DennisF said in 2.05.1 restart issues:
            In that case you need to get a M122 report. If the web interface won't connect, try getting one over USB.
            • DennisF
              Obviously while the device is under USB debugging it refuses to show the behavior. I did find something odd in my config that I fixed. It might explain it but I'm not sure, I didn't change back to investigate. The old config had the line:
              M587 SMYSSID PMYPASS"
              Note the trailing ". That is not part of the password.
                You should not have a M587 line in config.g. Remove it.
