    How is a "x+" layer shift even possible on a delta?
    • janjoh
      janjoh last edited by
      Hello!
      Sooo, to my surprise I woke up this morning and found a "clean" layer shift in X+ direction on my delta printer. I wasn't even aware that this was possible given the kinematics. I thought a delta loosing steps would mean a pretty catastrophic failure.
      I found a few articles that adviced to look for missed steps in M122. And I do not appear to have those.
      As for currents, I am at 1A with these motors https://www.robotdigg.com/product/1250/0.9-step-angle-NEMA17-stepper-motors
      M906 X1000 Y1000 Z1000 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
      Where should I start to look for this, or is this a "once and never again" sort of thing you think? Again, I think I am mainly confused that this would happen in the first place.
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-95BLL-N6PSS-6JKD2-3SD6Q-1JTRM
      Used output buffers: 1 of 24 (15 max)
      Static ram: 25712
      Dynamic ram: 93044 of which 0 recycled
      Exception stack ram used: 528
      Never used ram: 11788
      Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3760) IDLE(ready,160)
      Owned mutexes:
      Last reset 11:57:28 ago, cause: power up
      Last software reset at 2020-06-08 20:09, reason: User, spinning module GCodes, available RAM 11828 bytes (slot 3)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 44.8, current 45.0, max 49.0
      Supply voltage: min 24.3, current 24.5, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2020-06-12 06:21:38
      Slowest loop: 2.12ms; fastest: 0.08ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 3, completed moves: 3, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 202.17ms; fastest: 0.08ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        Failed messages: pending 0, notready 0, noresp 1
        WiFi firmware version 1.23
        WiFi MAC address 2c:3a:e8:0a:f1:44
        WiFi Vcc 3.31, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 24696
        WiFi IP address 172.25.74.150
        WiFi signal strength -57dBm, reconnections 0, sleep mode modem
        === Filament sensors ===
        Extruder 0: pos 223.95, errs: frame 0 parity 0 ovrun 0 pol 7 ovdue 0
        Surprisingly, skipping steps on one tower of a delta does give symptoms that at first glance look like a layer shift, aligned towards the tower that had the skipped step. If you look more closely, you may notice that the size of the layer shift isn't constant across the whole print.
        I expect it's a one-off, so I suggest you retry the print.
        janjoh 1 Reply Last reply Reply Quote 0
        • janjoh
          janjoh @dc42 last edited by
          @dc42 said in How is a "x+" layer shift even possible on a delta?:
          Surprisingly, skipping steps on one tower of a delta does give symptoms that at first glance look like a layer shift, in the aligned towards the tower that had the skipped step. If you look more closely, you may notice that the size of the layer shift isn't constant across the whole print.
          Yeah, seem to be, and I think I have found the reason. While reprinting i found that these support structures were curling quite a lot during print and my hot end did run in to them at a few occasions.
          I wonder if that angle can be made less aggressive without completely disabling Gradual support infill steps.
            Phaedrux Moderator @janjoh last edited by
            @janjoh said in How is a "x+" layer shift even possible on a delta?:
            You might be able to set a thicker wall for infill to keep it from curling as much or set a fan override for infill.
