IR Z probe with 2 trigger height
I had the DC42 IR Z-probe set up and working perfectly for the last 2 weeks.
This morning, home Z left the nozzle a lot higher than previously.
Apparently, there is now two trigger points for the Z-probe - one at 1.5mm and the second at 7mm.
The nozzle and probe are clean.
How should I go about getting rid of that second trigger point?Thanks,
CJ
Hi CJ,
I'm sorry to have missed this post when you first made it. I have asked Filastruder to replace your sensor under warranty. You do not need to return the faulty one.
Best regards David
Just got the email from Filastruder. Thank you.
You guys are awesome!
CJ
