    Official Raspberry PI 7" touchscreen power from Duet 3
    • Stephen6309undefined
      Stephen6309
      Is there any place on the Duet 3 6HC I can get 5vdc for the Official Raspberry PI 7" touchscreen?
      • aidarundefined
        aidar
        https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram
        • A Former User?
          A Former User
          Please take care not to load the Duet 5v beyond 3A.
          Edit: sidenote to the below, any 1mm pitch 15pin FFC (FPC) cable will work for Pi screen (and camera)
            Stephen6309
            Today I tried the 7" touchscreen. Wired the +5 and GND using the DOTSTAR connection, plug in the too short flat cable, and it worked fine. I have a long camera cable on order from amazon for it, the cam cable and the screen cable are the same.
              Stephen6309
              Received the 1 meter camera extension from Amazon and made a long power cable. The screen works fine.
                Stephen6309
                Update:
                The pi4 was showing the low voltage lightning on the screen. Now powering from a 5vdc Meanwell.
