    Status not working after RRF3 upgrade
    Duet Web Control
    300
    • Liquid3Dundefined
      Liquid3D
      After upgrading to RRF 3 the job status / Layer chart no longer update.
      After the upgrade my SD card had issues and needed to be formatted. I rebuilt the SD card and everything seems to work correctly except the Layer status does not update. Current layer time shows the count down but last layer time is always N/A and the chart is blank.
      I have tried reinstalling the newest version of DWC. What could cause this issue? maybe a missing file?
      DWC - 3.1.1
      RRF - 3.1.1
      Wifi Swerver - 1.23
        First verify your firmware version by sending M115.
        If you're actually running 3.1.1 and the DWC version is showing as 3.1.1 the problem may be in your start/end gcode, so please post an example sliced file.
        • Liquid3Dundefined
          Liquid3D
          slot cover.txt m115
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-05-19b2
          Here is the Start code. Full file attached
          M107
          M404 D0.4
          M140 S70
          M104 S170
          M190 S70
          G28
          M190 S70
          M104 S250
          G92 E0
          G1 X130 Y280 Z0.3 F2000
          M109 S250
          G1 X40 E20 F1000
          G1 Y170 F2000
          G92 E0
          M572 D0 S0.7
          G21
          G90
          M83
          G1 Z0.2 F7800
          G1 E-2 F3600
          G1 X22.326 Y110.903 F7800
          G1 E2 F2400
          [0_1592744431586_slot cover.gco](Uploading 100%)
            What slicer are you using?
            • Liquid3Dundefined
              Liquid3D
              Prusa Slicer.
                Did you clean up the file? I don't see any of the prusa slicer content.
                • Liquid3Dundefined
                  Liquid3D
                  no I did not cleanup any of it. it's the older Prusa Slicer 1.41.1
                    Ah yes, that's quite old. I would suggest you update to 2.2 for compatibility with RRF3.
                    • Liquid3Dundefined
                      Liquid3D
                      Thank you i'll give that a try and report back.
                      • Liquid3Dundefined
                        Liquid3D
                        Phaedrux, Thank you for the help that seems to have resolved the issue.
