Upgraded to DuetWiFiServer 1.03-ch - can't connect
  • As per the recommendation for solving the ajax issue in the browser. I was updating the firmware, DuetWifiServer , the firmware worked nicely, after uploading the DuetWifiServer was uploaded I can no longer stay connected via USB.
    I can no longer stay connected via Repetier-Host and nothing is starting. How can I resolve this…
    I upgraded firmware first.
    [[language]]
    < 6:45:30 PM: daemon: M208 X300 Y200 Z300
    < 6:45:30 PM: daemon: M208 X0 Y0 Z0 S1
    < 6:45:30 PM: daemon: G21
    < 6:45:30 PM: daemon: G90
    < 6:45:30 PM: daemon: M83
    < 6:45:30 PM: daemon: M558 P1 F500 X0 Y0 Z0
    < 6:45:30 PM: daemon: G31 X150 Y100 Z0 P400
    < 6:45:30 PM: daemon: M305 P0 T100000 B4388 R4700 H0 L0
    < 6:45:30 PM: daemon: M305 P1 T100000 B4388 R4700 H0 L0
    < 6:45:30 PM: daemon: M301 H1 P10 I0.10 D100 T0.50 S1.0
    < 6:45:30 PM: daemon: M570 S120
    < 6:45:30 PM: M570 S parameter is no longer required or supported
    < 6:45:30 PM: daemon: M106 P1 T45 H1
    < 6:45:30 PM: daemon: M563 P1 D0 H1
    < 6:45:30 PM: daemon: G10 P1 S0 R0
    < 6:45:30 PM: daemon: M556 S78 X0 Y0 Z0
    < 6:45:30 PM: daemon: M208 S1 Z0
    < 6:45:30 PM: daemon: M501
    < 6:45:30 PM: Can't open 0:/sys/config-override.g to read, error code 4
    < 6:45:30 PM: Macro file config-override.g not found.
    < 6:45:30 PM: daemon: T0
      6:45:51 PM: Connection closed
  • Update. I just was able to connect.. then the above happened again.
    [[language]]
    < 6:58:28 PM: daemon: T0
    > 6:58:28 PM: N819 M111 S6 *71
    < 6:58:28 PM: ok
    < 6:58:28 PM: serial: N817 M115 *8
    < 6:58:28 PM: FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.18.1 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-04-09
    > 6:58:28 PM: N820 M111 S14 *126
    < 6:58:28 PM: ok
    < 6:58:28 PM: serial: N818 M105 *6
    < 6:58:28 PM: ok T:B:23.5
      6:58:48 PM: Connection closed
      6:58:53 PM: Attempting to connect to printer
      6:58:53 PM: Connection opened
    > 6:58:54 PM: N822 M110 *11
    < 6:58:54 PM: ok T:B:23.6
    > 6:58:54 PM: N823 M115 *15
    < 6:58:54 PM: daemon: M569 P1 S1
    < 6:58:54 PM: daemon: M569 P2 S0
    < 6:58:54 PM: daemon: M569 P3 S1
    < 6:58:54 PM: daemon: M569 P4 S1
    < 6:58:54 PM: daemon: M574 X1 Y2 S0
    < 6:58:54 PM: daemon: M574 Z2 S1
    < 6:58:54 PM: daemon: M350 X16 Y16 Z16 E16 I1
    < 6:58:54 PM: daemon: M92 X100 Y100 Z400
    < 6:58:54 PM: daemon: M92 E138.4:138.4
    < 6:58:54 PM: daemon: M906 X800 Y800 Z800 E800
    < 6:58:54 PM: daemon: M201 X1500 Y1500 Z300 E4000
    < 6:58:54 PM: daemon: M203 X15000 Y15000 Z300 E1500
    < 6:58:54 PM: daemon: M566 X600 Y600 Z24 E300
    < 6:58:54 PM: daemon: M208 X300 Y200 Z300
    < 6:58:54 PM: daemon: M208 X0 Y0 Z0 S1
    < 6:58:54 PM: daemon: G21
    < 6:58:54 PM: daemon: G90
    < 6:58:54 PM: daemon: M83
    < 6:58:54 PM: daemon: M558 P1 F500 X0 Y0 Z0
    < 6:58:54 PM: daemon: G31 X150 Y100 Z0 P400
    < 6:58:54 PM: daemon: M305 P0 T100000 B4388 R4700 H0 L0
    < 6:58:54 PM: daemon: M305 P1 T100000 B4388 R4700 H0 L0
    < 6:58:54 PM: daemon: M301 H1 P10 I0.10 D100 T0.50 S1.0
    < 6:58:54 PM: daemon: M570 S120
    < 6:58:54 PM: M570 S parameter is no longer required or supported
    < 6:58:54 PM: daemon: M106 P1 T45 H1
    < 6:58:54 PM: daemon: M563 P1 D0 H1
    < 6:58:54 PM: daemon: G10 P1 S0 R0
    < 6:58:54 PM: daemon: M556 S78 X0 Y0 Z0
    < 6:58:54 PM: daemon: M208 S1 Z0
    < 6:58:54 PM: daemon: M501
    < 6:58:54 PM: Can't open 0:/sys/config-override.g to read, error code 4
    < 6:58:54 PM: Macro file config-override.g not found.
    < 6:58:54 PM: daemon: T0
      6:59:14 PM: Connection closed
  • Update:
    I just cloned the config file, I thought it was that that was affecting the connection. The console provides more output now but still disconnects. The fan is spinning up frequently also like the board is restarting.
    [[language]]
      7:09:05 PM: Connection opened
    > 7:09:05 PM: N851 M110 *15
    < 7:09:05 PM: ok T:B:23.0
    > 7:09:05 PM: N852 M115 *9
    < 7:09:05 PM: daemon: M569 P1 S1
    < 7:09:05 PM: daemon: M569 P2 S0
    < 7:09:05 PM: daemon: M569 P3 S1
    < 7:09:05 PM: daemon: M569 P4 S1
    < 7:09:05 PM: daemon: M574 X1 Y2 S0
    < 7:09:05 PM: daemon: M574 Z2 S1
    < 7:09:05 PM: daemon: M350 X16 Y16 Z16 E16 I1
    < 7:09:05 PM: daemon: M92 X100 Y100 Z400
    < 7:09:05 PM: daemon: M92 E138.4:138.4
    < 7:09:05 PM: daemon: M906 X800 Y800 Z800 E800
    < 7:09:05 PM: daemon: M201 X1500 Y1500 Z300 E4000
    < 7:09:05 PM: daemon: M203 X15000 Y15000 Z300 E1500
    < 7:09:05 PM: daemon: M566 X600 Y600 Z24 E300
    < 7:09:05 PM: daemon: M208 X300 Y200 Z300
    < 7:09:05 PM: daemon: M208 X0 Y0 Z0 S1
    < 7:09:05 PM: daemon: G21
    < 7:09:05 PM: daemon: G90
    < 7:09:05 PM: daemon: M83
    < 7:09:05 PM: daemon: M558 P1 F500 X0 Y0 Z0
    < 7:09:05 PM: daemon: G31 X150 Y100 Z0 P400
    < 7:09:05 PM: daemon: M305 P0 T100000 B4388 R4700 H0 L0
    < 7:09:05 PM: daemon: M305 P1 T100000 B4388 R4700 H0 L0
    < 7:09:05 PM: daemon: M301 H1 P10 I0.10 D100 T0.50 S1.0
    < 7:09:05 PM: daemon: M570 S120
    < 7:09:05 PM: M570 S parameter is no longer required or supported
    < 7:09:05 PM: daemon: M106 P1 T45 H1
    < 7:09:05 PM: daemon: M563 P1 D0 H1
    < 7:09:05 PM: daemon: G10 P1 S0 R0
    < 7:09:05 PM: daemon: M556 S78 X0 Y0 Z0
    < 7:09:05 PM: daemon: M208 S1 Z0
    < 7:09:05 PM: daemon: M501
    < 7:09:05 PM: daemon: M111 S1
    < 7:09:05 PM: serial: N851 M110 *15
    < 7:09:05 PM: daemon: M550 PDBotCoreXY
    > 7:09:05 PM: N854 M111 S6 *78
    < 7:09:05 PM: ok
    < 7:09:05 PM: daemon: M551 Preprap
    < 7:09:05 PM: serial: N852 M115 *9
    < 7:09:05 PM: FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.18.1 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-04-09
    > 7:09:05 PM: N855 M111 S14 *124
    < 7:09:05 PM: ok
    < 7:09:05 PM: daemon: M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED
    < 7:09:05 PM: serial: N853 M105 *9
    < 7:09:05 PM: daemon: M552 S1
    < 7:09:05 PM: daemon: M555 P2
    < 7:09:05 PM: daemon: M667 S1
    < 7:09:05 PM: daemon: M569 P0 S0
    < 7:09:05 PM: serial: N854 M111 S6 *78
    < 7:09:05 PM: ok
    < 7:09:05 PM: serial: N855 M111 S14 *124
    < 7:09:05 PM: ok
    < 7:09:05 PM: serial: N856 M105 *12
    < 7:09:06 PM: daemon: M570 S120
    < 7:09:06 PM: M570 S parameter is no longer required or supported
    < 7:09:06 PM: daemon: M106 P1 T45 H1
    < 7:09:06 PM: daemon: M563 P1 D0 H1
    < 7:09:06 PM: daemon: G10 P1 S0 R0
    < 7:09:06 PM: daemon: M556 S78 X0 Y0 Z0
    < 7:09:06 PM: daemon: M208 S1 Z0
    < 7:09:06 PM: daemon: M501
    < 7:09:06 PM: daemon: M111 S1
    < 7:09:06 PM: daemon: M550 PDBotCoreXY
    < 7:09:06 PM: daemon: M551 Preprap
    < 7:09:06 PM: daemon: M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED
    < 7:09:06 PM: daemon: M552 S1
    < 7:09:06 PM: daemon: M555 P2
    < 7:09:06 PM: daemon: M667 S1
    < 7:09:06 PM: daemon: M569 P0 S0
    < 7:09:06 PM: daemon: M569 P1 S1
    < 7:09:06 PM: daemon: M569 P2 S0
    < 7:09:06 PM: daemon: M569 P3 S1
    < 7:09:06 PM: daemon: M569 P4 S1
    < 7:09:06 PM: daemon: M574 X1 Y2 S0
    < 7:09:06 PM: daemon: M574 Z2 S1
    < 7:09:06 PM: daemon: M350 X16 Y16 Z16 E16 I1
    < 7:09:06 PM: daemon: M92 X100 Y100 Z400
    < 7:09:06 PM: daemon: M92 E138.4:138.4
    < 7:09:06 PM: daemon: M906 X800 Y800 Z800 E800
    < 7:09:06 PM: daemon: M201 X1500 Y1500 Z300 E4000
    < 7:09:06 PM: daemon: M203 X15000 Y15000 Z300 E1500
    < 7:09:06 PM: daemon: M566 X600 Y600 Z24 E300
    < 7:09:06 PM: daemon: M208 X300 Y200 Z300
    < 7:09:06 PM: daemon: M208 X0 Y0 Z0 S1
    < 7:09:06 PM: daemon: G21
    < 7:09:06 PM: daemon: G90
    < 7:09:06 PM: daemon: M83
    < 7:09:06 PM: daemon: M558 P1 F500 X0 Y0 Z0
    < 7:09:06 PM: daemon: G31 X150 Y100 Z0 P400
    < 7:09:06 PM: daemon: M305 P0 T100000 B4388 R4700 H0 L0
    < 7:09:06 PM: daemon: M305 P1 T100000 B4388 R4700 H0 L0
    < 7:09:06 PM: daemon: M301 H1 P10 I0.10 D100 T0.50 S1.0
    < 7:09:06 PM: Push(): stack overflow!
    < 7:09:06 PM: daemon: T0
      7:09:26 PM: Connection closed
    Looks like you have a M111 S1 command at the start of config.g to enable debug output. For normal operation you should remove it, or change it to M111 S0.
  • I just changed it to M111 S0. Rebooted and still not able to stay connected.
    The board seems to be rebooting consistently.
    I installed DuetWiFiFirmware-1.18.1.bin via web control. Started fine
    I installed DuetWiFiServer-1.03-ch.bin via web control / asked to install (was connected via USB for status) and after it restarted this is the state that it is currently in.
    Tried Solutions
    • config-override.g not found - created in /sys - No Effect - Just resolved the file not found error
    • Changed M111 to S0 - No Effect
    • Reverted to 1.16 via SamBa- No Effect
    • Updated to 1.17 via SamBa - No Effect
    • Resinstalled to 1.18 via SamBa - No Effect
    Repetier Host will not stay connected for more than a few seconds where the it appears that the board reboots - there is certainly an issue somewhere that came after installing the new versions .
    This is the read out in the Rephost. Please advise. I have re-flashed the firmware from Sam-ba and no change.
    Also, cannot run GCODE commands, never connected long enough.
    [[language]]
      9:23:14 AM: Connection opened
    > 9:23:14 AM: N1 M110 *2
    < 9:23:14 AM: ok T:B:2000.0
    > 9:23:14 AM: N2 M115 *4
    < 9:23:14 AM: M570 S parameter is no longer required or supported
    > 9:23:14 AM: N4 M111 S6 *67
    < 9:23:14 AM: ok
    > 9:23:14 AM: N5 M111 S14 *113
    < 9:23:14 AM: FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.17e ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-02-10
    < 9:23:14 AM: ok
    < 9:23:14 AM: ok
    < 9:23:14 AM: daemon: M566 X600 Y600 Z24 E300
    < 9:23:14 AM: serial: N5 M111 S14 *113
    < 9:23:14 AM: ok
    < 9:23:14 AM: daemon: M208 X300 Y200 Z300
    < 9:23:14 AM: daemon: M208 X0 Y0 Z0 S1
    < 9:23:14 AM: daemon: G21
    < 9:23:14 AM: daemon: G90
    < 9:23:14 AM: daemon: M83
    < 9:23:14 AM: daemon: M558 P1 F500 X0 Y0 Z0
    < 9:23:14 AM: daemon: G31 X150 Y100 Z0 P400
    < 9:23:14 AM: daemon: M305 P0 T100000 B4388 R4700 H0 L0
    < 9:23:14 AM: daemon: M305 P1 T100000 B4388 R4700 H0 L0
    < 9:23:14 AM: daemon: M301 H1 P10 I0.10 D100 T0.50 S1.0
    < 9:23:14 AM: daemon: M570 S120
    < 9:23:14 AM: daemon: M106 P1 T45 H1
    < 9:23:14 AM: daemon: M563 P1 D0 H1
    < 9:23:14 AM: daemon: G10 P1 S0 R0
    < 9:23:14 AM: daemon: M556 S78 X0 Y0 Z0
    < 9:23:14 AM: daemon: M208 S1 Z0
    < 9:23:14 AM: daemon: M501
    < 9:23:14 AM: Push(): stack overflow!
    < 9:23:14 AM: serial: N6 M105 *1
    < 9:23:14 AM: daemon: T0
      9:23:34 AM: Connection closed
  • Update:
    It seemed like the hangup was starting up the wifiserver. Didn't know why I didn't think of this before, I removed the startup code for the wifi in config and it all started up nicely. Re-installed wifiserver via usb. Seems to be all in line now.
    Ajax issue seems to be fixed in webcontrol as well.
    Sorry for the lengthy posts, self learning can be painful sometimes 🙂
    I don't like the look of this:
    Unless you have 5 T0 commands near the end of your config.g file, it looks like you have an infinite recursion in a gcode file. I suggest you delete config-override.g, comment out the M501 command in config.g, and try again.
