    Weird boot with runout sensors enabled
    Filament Monitor
    • HtRabbit
      HtRabbit last edited by HtRabbit
      I am having a weird issue when i have my 2 runout sensors enabled and no filament loaded.
      during the boot the system will hang and i cannot connect with the web panel until one of the 2 extruders has some filament loaded.
      ;Filament Sensors
      M591 D0 P2 C"e0_stop" S1   			   ;Extruder 1(0)
      M591 D1 P2 C"e1_stop" S1   			   ;Extruder 2(1)
      Both sensors are working and being detected fine, and a M591 D0 or a M591 D1 show the status properly.
      both are identical sensors and are plugged in the same.
      If i disable the e1_stop and disconnect it it seems to boot fine.
        Please upgrade to firmware 3.1.1
        There have been many improvements and fixes since version 3.0.
        • HtRabbit
          ok, i upgraded to 3.1.1 firmware all paneldue and homing is working.
          if i boot with no filament nothing boots (no end stop lights or wifi lights on board) as soon as i insert filament in either runout sensor(extruder 0 or 1, doesn't matter) my board lights up and i can connect fine.
          I can have either runout sensor with no filament , but not both. if they both run out wifi shuts off and system goes dark.
          When i Only had 1 runout sensor all was ok
          Not sure where to look next, Or should i just make sure only 1 extruder runs out.......LOL
          M208 X330 Y300 Z400 S0                             ; set axis maxima
          M574 X1 S1 P"xstop"                                ; configure active-low May need ! before pin name to invert signal, S0 Retired
          M574 Y1 S1 P"ystop"                                ; configure active-low May need ! before pin name to invert signal, S0 Retired
          M574 Z1 S2 P"zstop+e2stop" 			   ; configure active-high endstops for low end on Z via pins zstop and e2stop
          ;Filament Sensors
          ;M581 P"e0stop" T1 C0                              ;Any trigger number # greater than 1 causes the macro file sys/trigger#.g to be executed.
          M950 S0 C"duex.e6heat"                             ; create servo pin 0 for BLTouch
          M558 P9 C"zprobe.in+zprobe.mod" H5 F300 T6000      ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X-20 Y51 Z1.6                             ; set Z probe trigger value, offset and trigger height org=Z1.47
          M557 X0:330 Y0:330 S75                           ; define mesh grid
          Electronics
          Diagnostics
          Board: Duet 2 WiFi (2WiFi)
          Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
          Duet WiFi Server Version: 1.23
          6/17/2020, 8:40:28 PM
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DJM-9178L-L2MS8-6JTF4-3S86S-99GLP
          Used output buffers: 3 of 24 (16 max)
          Static ram: 27980
          Dynamic ram: 94932 of which 60 recycled
          Exception stack ram used: 552
          Never used ram: 7548
          Tasks: NETWORK(ready,364) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1540) IDLE(ready,80)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:11:56 ago, cause: power up
          Last software reset at 2020-06-17 19:23, reason: User, spinning module GCodes, available RAM 7828 bytes (slot 2)
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
          Error status: 0
          MCU temperature: min 32.8, current 34.5, max 36.6
          Supply voltage: min 12.1, current 12.5, max 12.8, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: standstill, SG min/max 0/225
          Driver 1: standstill, SG min/max 0/184
          Driver 5: standstill, SG min/max not available
          Driver 6: standstill, SG min/max not available
          Driver 7: standstill, SG min/max not available
          Driver 8: standstill, SG min/max not available
          Driver 9: standstill, SG min/max not available
          Date/time: 2020-06-17 20:40:28
          Cache data hit count 1133096795
          Slowest loop: 90.19ms; fastest: 0.14ms
          === Storage ===
          Free file entries: 9
          SD card longest read time 3.2ms, write time 18.9ms, max retries 0
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 146, MaxWait: 130270ms
          === MainDDARing ===
          Scheduled moves: 421, completed moves: 421, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
          === AuxDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
          Heater 1 is on, I-accum = 0.4
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 40.19ms; fastest: 0.00ms
          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.23
          WiFi MAC address cc:50:e3:e3:ac:2c
          WiFi Vcc 3.38, reset reason Unknown
          WiFi flash size 4194304, free heap 22600
          WiFi IP address 192.168.0.125
          WiFi signal strength -42dBm, reconnections 0, sleep mode modem
          Socket states: 4 0 0 0 0 0 0 0
          === Filament sensors ===
          Extruder 0 sensor: ok
          Extruder 1 sensor: no filament
          === DueX ===
          Read count 1, 0.08 reads/min
          6/17/2020, 8:36:27 PM
          Printing paused at X135.2 Y165.8 Z0.3
          6/17/2020, 8:36:21 PM
          Resume state saved
          6/17/2020, 8:36:02 PM
          Printing paused at X133.9 Y165.8 Z0.3
          6/17/2020, 8:35:56 PM
          Resume state saved
          6/17/2020, 8:32:38 PM
          20 points probed, min error -0.030, max error 0.227, mean 0.111, deviation 0.084
          Height map saved to file 0:/sys/heightmap.csv
          Error: Bad command: :G29
          6/17/2020, 8:31:14 PM
          Leadscrew adjustments made: -0.210 -0.220, points used 2, (mean, deviation) before (-0.215, 0.002) after (0.000, 0.000)
            What are the sensors and how are they wired?
            • HtRabbit
              I am using a lerge sensor
              • HtRabbit
                OK, This is why i like hanging around smart people,
                i needed to switch the red and black wires on the Duet 2 connector, and invert the M591 command
                ;Filament Sensors
                M591 D0 P2 C"!e0_stop" S1   			   ;Extruder 1(0)
                M591 D1 P2 C"!e1_stop" S1   			   ;Extruder 2(1)
                Thank you to all.
                this has been resolved.
