    Extra temperature controlled exhaust fans.
    fans heated enclosure enclosure nylon
    • sd_mattundefined
      sd_matt
      I plan to use exhaust fans on top to regulate a heated enclosure by pulling in outside air. Has anyone here set up additional temperature controlled fans? How do you do it? I'm building using a duet2 with expansion board
        No need to multi post.
