Unsolved Duet2 WiFi using heater pins for fans?
What I have:
Duet2WiFi
Firmware 3.1.1 (just upgraded from 2.05.1)
24v power supply
12v buck converter
Fans 0,1,2 being supplied 12v from converterMy fan2 is inoperable (probably mosfet) so I need to add two fans.
Following this example from the wiki
M950 F3 C"heater2" Q100 ; Fan 3 is connected to heater 2 pin, PWM at 100Hz
my config.g contains this under fans; Fans
M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
M950 F3 C"heater5" Q500 ; create fan 3 on pin heater5 pin, and set its PWM frequency at 500Hz
M106 P3 S0 H-1 ; set fan 0 value. Thermostatic control is turned offI have the power connected to same 12v converter as the onboard fans and the negative connected to the heater5 pin. I also tried C"ext.heater5" but had no better results. The fan runs continuaously and cannot be controlled by M106 commands. i.e.
M106 P3 S0 or M106 P3 S155, or M107 P3
Can someone point out my error?
Thanks -
You didn't mention a DueX, so I assume you don't have one. The exp.heater5 pin on the expansion connector is a low-current 3.3V-only pin, so it can't control a fan directly unless you use an external driver of some sort. You may well have damaged it if you connected a fan between it and +12V.
Can i use any of the pins on the expansion connector for a fan or laser control?
@GeorgeM said in Duet2 WiFi using heater pins for fans?:
they're all* have the same limits, if you need to sink or source any amount of current the answer is probably "no, not without a buffer or driver inbetween".
iirc most of the pins are in the 2-3mA range, so pretty much noting that isn't a very high impedance input is a no-go.
*some have a little more than 2-3mA but still not enough to drive anything like a fan
So to go off in a little bit of a different direction. Can I use one of the heater pins to control my laser. It will operate on 5 volts. Do I set it up as a servo as this example:
M950 P0 C"exp.heater5" ; create output/servo port 0 attached to heater 5 pin on expansion connector
Will doing it that way give me PWM control?
it would totally depend on how much current you need to sink or source into the laser, and if the pin would ever see 5v or not - also if 3.3v is sufficient to trigger the 5v input.
so it depends on the laser
The laser control can work on up to 24v. Here is the the laser driver specs:
Specifications:
Specification HCDBSAFDA2_5AMP
Current Source Range: 0 – 2.5 Amps
Current Limit Jumper Settings: 0.5, 1.0, 1.5, 2.0, 2.5 Amps
Compliance Voltage w/12V adapter: 8 volts
Current Resolution: 0.1%
Current Adjustment: Analog Trim Pot
Current Range Accuracy Always greater than limit, no more than 15%
Laser Diode Protection: Soft Start, Reverse Voltage, Current Limit, Thermal Shutdown
Integrated Safety Features Laser Enable Key Switch, Integrated Laser Interlock, Power off Reset, LED Indicators
AC Adapter Input Voltage: 100 – 240 VAC
Control Signal Digital Isolation Voltage: 4500 Vrms
Minimum Control Signal ”Turn On” Voltage: 2.8 Volts
Control Signal Maximum Voltage: 24 Volts
Control Signal Maximum Current: 50 ma
Control Signal Maximum Frequency: 5KHz
Connectors: Screw Terminal and Molex Mini-Fit Jr Connectors -
specs
insufficient data. yes it will trigger at 3.3v, but no info on impedance or source/sink current at 3.3v, only max current. 2.8v logic threshold leaves very little room for adding a series resistor to limit the current.
i'd measure the current at 3.3v or go with a buffer for good measure.
