    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    34.1k
    • A Former User?
      A Former User @wilriker
      @wilriker said in Duet 2 Ethernet and SBC:
      I tested with no resistors and with 500R
      thanks for your effort with this btw! which branch would be the best bet to build Duet2_SBC_RTOS/Duet2CombinedFirmware.bin? nvm checking that all the repos have been switched from dc42 to duet3d github turned out to be an idea
      smoki3undefined 1 Reply Last reply Reply Quote 0
      • smoki3undefined
        smoki3 @A Former User
        @bearer I build 3.02 branch with the SBC Configuration. This should work.
        The build have a different file name. So you have to rename it to flash it over DWC
        • wilrikerundefined
          wilriker @smoki3
          @smoki3 Yes, for initial flashing you have to rename it or flash it via bossa (as I did). If you also build DuetIAP and put this into the /sys folder of DSF you can from then on do regular flashing by just uploading the firmware file as is in DWC.
          Manuel
          My Tool Collection
          • smoki3undefined
            smoki3 @wilriker
            @wilriker is it a different DuetIAP as the normal build which is released on GitHub?
            • wilrikerundefined
              wilriker @smoki3
              @smoki3 Yes, it's a new version that will be part of the RRF 3.2.0. You have to clone DuetIAP and have to build SAM4E_SPI_RAM build configuration. This will create a file name Duet2_SBCiap_2SBC.bin.
              Manuel
              My Tool Collection
              • A Former User?
                A Former User
                @wilriker did you see anything like https://forum.duet3d.com/post/162547 in your testing?
                (that is with 330R inline on the MOSI, MISO and SCK signals, but the ESP is in place with its pins as hi-z and sleeping).
                i'll see if I can't put some 2.0mm headers on there so I can switch between WiFi and SBC but will take a while
                • wilrikerundefined
                  wilriker @A Former User
                  @bearer I remember that I have seen the
                  6/26/2020, 11:51:59 AM	Connection to Duet established
                  6/26/2020, 11:52:01 AM	Warning: Lost connection to Duet (Board is not available (no data response))
                  cycle at least once but I don't remember what the reason/solution was (as there were a lot of errors at that time 😁 ). And I have only ever tested with a Duet 2 Ethernet.
                  Unlikely but: did you use the GPIO0 on the ESP as the TransferReady pin? I remember that while testing I got confused that the header for Ethernet does not have all the pins that the ESP needs and thus some contact points where not what I expected in the first place. Usually if you get that wrong DSF will complain about Duet not being available, though.
                  EDIT: I only now saw that you get a connection every once in a while (in your example to issue M115). That means basic connection is working. And if SPI speed would be too high that would result in checksum errors rather than no data errors.
                  EDIT2: There have been a lot of refactorings lately. Let me quickly check if it still works on my test hardware.
                  EDIT3: That still works (although I get an error with DCS not being able to deserialize a status update but that's something different).
                  Manuel
                  My Tool Collection
                  • A Former User?
                    A Former User
                    @wilriker haha! Don't worry about it too much, it was just a stab in the dark as I had someone to help me with the wiring. I'll get back to it in a couple of weeks.
                    Anyways yes, i did use gpio0 or EDR_CONN as the net is called, which looked to be the same pin the w5500 uses, and as M115 did manage to sneak through I presumed that was ok. And despite not seeing checksum errors I tried dropping the SPI speed but made no difference.
                    I just wanted to see if it was possible to not remove the ESP, so far either i messed up hi-z firmware, or it has to GTFO. Thanks for taking a look!
                    • smoki3undefined
                      smoki3
                      It has a 5V 3A regulator on it for the raspberry
                      A Former User? 1 Reply Last reply Reply Quote 2
                      • A Former User?
                        A Former User @smoki3
                        @smoki3 said in Duet 2 Ethernet and SBC:
                        have you considered the load on the 1A fuse for the fans when you're taking a good chunk out for the 5v buck?
                          @bearer said in Duet 2 Ethernet and SBC:
                          If the firmware sets up the ESP reset pin and EN pins as outputs in the low state, then I think it should work without disconnecting the ESP. The additional capacitance of the ESP pins might reduce the maximum available SPI speed a little, but that speed isn't critical.
                          • A Former User?
                            A Former User @dc42
                            @dc42 said in Duet 2 Ethernet and SBC:
                            I feel like I'm missing something obvious here; will have a think or two and make a new topic when I've figured it out, or figured out that I'm not gonna figure it out
                            edit: nope, doesn't compute. as suspected, were missing something obvious .. 🤦
                            • smoki3undefined
                              Yes you are right. I thought the always on Fan are directly connected to VIN
                              • A Former User?
                                Now you are right. I thought the always on Fan are directly connected to VIN
                                might not be a problem, you should have 3-400mA left for fans driven by Vin, I was just trying to make sure you'd take it into account.
                                edit: I've used some of these type of things to tap the fuse for putting on a step down for fans (mini - not low profile, ATM or ATP fuse)
                                https://www.ebay.com/sch/i.html?_nkw=atp+fuse+tap
                                • smoki3undefined
                                  smoki3
                                  ../src/Libraries/Fatfs/diskio.c:51:10: fatal error: ctrl_access.h: No such file or directory
                                     51 | #include "ctrl_access.h"
                                  compilation terminated.
                                  make: *** [src/Libraries/Fatfs/diskio.o] Error 1
                                  make: *** Waiting for unfinished jobs....
                                  I get this when I try to build DuetIAP. Building in mac.
                                  A Former User? wilrikerundefined 2 Replies Last reply Reply Quote 0
                                  • A Former User?
                                    i got the same, but as long as you can use Bossa to do any programming after the inital flashing you don't need the IAP binary
                                    • smoki3undefined
                                      smoki3
                                      So tested my PCB today. Its working fine. 🙂 So I just miss the IAP that I can flash the duet trough DWC.
                                      • smoki3undefined
                                        smoki3
                                        With SBC there is no SD card needed in the duet right?
                                        • A Former User?
                                          it explicitly needs to not have a SD card with a config.g on it. (at least for now (RRF3.2), been some discussion on changing that)
                                          • smoki3undefined
                                            I got it 😄 I removed the SD Card now my config is working
