Finger trouble
  • Hi all, I have my Duet Wifi working quite well for a month or more, but I don't know what I have done but if I use Down Loadans Print button it go's green as if it has down loaded and then say's print compleate, but nothing happens. If I Upload the G code button it go's black but just keeps telling me it is loading, I have four Gcode been down loading for over a week. is this finger trouble?? Or what have I done wrong.
    Thanks
    Mike
    It could indicate a problem with the SD card. Try moving it to a PC and checking it;. Under Windows you do this by right clicking on the drive in File Explorer, select Properties, then Tools, then Check.
  • hi it say's nothing wrong with card, i have removed the GCodes that would not down load but when I try to down load it tell me print compleate.
    Mike
  • M32 Speed Tank 3 17 v1.stl
    File Speed Tank 3 17 v1.stl selected for printing
    Done printing file
    This what I get when I download, I have printed this file but can't do it a gain or down load it or print it.
    Mike
    You can't print an STL file, you need to slice it to a gcode file first.
  • Hi ,for your help, for some reaon simply 3D was not saving the Gcode.
    Mike
