UNSOLVED DWC Send Command Button Bug
I just updated to the most recent version of DWC and noticed that the send button needs to be pressed twice in order to send a g-code command. I suspect this is a bug and not a feature request;)
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
Duet WiFi Server Version: 1.23
Thanks for the report. @chrishamm can confirm.
It's just the first time after the application loads, it needs an extra click. After that it works as expected.
It's not a new bug, also mentioned here:
https://forum.duet3d.com/topic/16303/code-send-button-misbehavior
I get the same thing but I had put it down to it being something to do with the very old Laptop I'm using. DWC takes longer to connect than the older version too.
