    Recent v3.02-dev on Duet 2 Wifi
    Firmware installation
    • vdenundefined
      vden
      I'm trying to install recent build of RRF from v3.02 branch to my Duet 2 Wifi 1.04 running stable RRF 3.1.1, 'cause I want to connect 12864 display and as far as I can see @dc42 has finally added its support in that branch.
      The building process was completed without an issue, build configurations was selected according to `Build instructions' document.
      After that I tried to upload new firmware bin file (from Duet2_RTOS directory) with DWC2 and the board hadn't boot anymore neither was accessible by USB (DIAG led is on). I was able to burn stable 3.1.1 firmware back via SAM-BA after erasing.
      I tried to burn 3.02-dev firmware with SAM-BA too, but got the same result. Nothing is working, DIAG led is on.
      Is any commit after abb62a3 from 3.02-dev considered to be working on Duet 2 Wifi? Or I'm doing smth wrong?
      Thank you.
      • A Former User?
        A Former User
        odd, i would think you forgot to reset the board after flashing, but given you get back to 3.1.1 then maybe not.
        i'm running commit 4deb8a06da43688622f0196ddc3f52f74415ed99 (HEAD -> v3.02-dev, origin/v3.02-dev) and it works fine with a pi on a Duet 2 Wifi rev 1.04. (i used bossa, IAP also worked)
        edit: just relized the non sbc build may differ, but it works fine as well.
        vdenundefined 1 Reply Last reply Reply Quote 0
        • vdenundefined
          vden @A Former User
          @bearer Thank you for reply.
          I did reset after flashing of course (is it enough to press reset micro-button next to usb slot for that?)
          I'll try that commit then. Can't see any breaking changes between it and HEAD though but anyway.
          • A Former User?
            A Former User @vden
            @vden said in Recent v3.02-dev on Duet 2 Wifi:
            yeah, reset is enough. i prefer the command line version as it has an -R flag to reset after flashing.
            you can try this binary to rule out something with the build setup if you like Duet2Combined-3.02-dev.zip
