PanelDue font header format change proposal
  • Current header:
    extern const uint8_t glcd28x32[] =
    28, // character width in pixels
    32, // row height in pixels
    3, // space columns between characters before kerning
    0x20, // first character code
    0xFF, // last character code
    Proposal:
    2, // character ranges (1-255)
    0x20, 0x00, // first character code (16-bit little-endian value, range 1)
    0xFF, 0x00, // last character code (16-bit little-endian value, range 1)
    0x10, 0x04, // first character code (16-bit little-endian value, range 2)
    0x4F, 0x04, // last character code (16-bit little-endian value, range 2)
    Offset of first character is (number of ranges)*4 + 4.
    The goal of this proposal is to enable more locales (cyrillic, eastern, etc) but save flash memory by not including complete unicode fonts, only certain ranges
    That looks good to me. When you add new characters, make sure they come from open source fonts.
  • Proof-of-concept implementation of non-continuous unicode fonts for PanelDue. In this patch I added Russian alphabet (Unicode characters from 1040 (0x0410) to 1103 (0x044F)) to the glcd28x32 font. I used the same Liberation Sans font (Windows size 22) and it looks great. I replaced Control button label with first and last chars from second font range and it works okay.
    Firmware size is still acceptable (~101kb) so I can make a full Russian locale now.
  • Any ideas how to place more locale labels on screen? There is a room for 4 locales, what if I want to add 5th or 6th?
    Can you have the locale button open a scrollable dialog box (like we have for selecting g-code files)? that way you can have as many locales as you like.
