    Duet V2 and firmware v3
    Firmware installation
    • peirofundefined
      peirof
      Aprox. a month ago I asked if Firmware v3. X it's stable in a Duet V2 board.... And the community recommend me wait until a stable version its released...
      The actual version of firmware v3, for Duet V2 boards.... Its stable now?
      Thanks
        Version 3.1.1 RRF/DWC seems to be doing quite well for people. The online config tool has been updated for RRF3 as well. Version 3.2 is around the corner.
        So if you've got a fairly standard printer setup you can probably update using a config from the config tool and be up and running without too much trouble.
        You should update from 2.05 to 3.0 to 3.1.1 using the full zip file upload in DWC.
