Cold extrusion not disabling extrusion on expansion board D3+3HC
I have a toolchanger and I wanted to do a dry run.
With all heaters at 0 my extruder still turns.
Running 3.1.1 on Duet3 6HC +3HC. Tools on 3HC.
Is this another limitation of the expansion boards?And I have checked that M302 does not allow cold extrusions.
Here's my tool definition:
; Tool 0 ; Create Heater M308 S1 P"1.temp0" Y"thermistor" T100000 B4725 C0.0000000706 A"T0 Heater" ; configure sensor 1 as thermistor on pin temp0 M950 H1 C"1.out0" T1 ; create nozzle heater output on out0 and map it to sensor 1 M143 H1 S300 ; set temperature limit for heater 1 to 300C (e3d v6 all metal) M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Create Part Fan M950 F1 C"1.out3" ; Define Part Cooling fan on out3 (4pin) M106 P1 C"Part Cooling T0" ; Setup Part Cooling Fan as Part Cooling T0 ; Create Hotend Fan M950 F2 C"1.out6" ; Define Hotend Fan on out6 (2pin) M106 P2 S255 T45 H1 ; Setup Hotend Fan for thermal control, full on when H1 reaches 45C ; Create Tool M563 P0 S"Tool 0" D0 H1 F1 ; Define tool 0 M572 D0 S0.025 ; Set pressure advance on Extruder Drive 0
