    Faster trigger of M80 command with duet3 + SBC
    1
    135
    • nrivieraundefined
      nriviera
      Is there a faster was of triggering an M80 command from boot? All the power for my printer is powered through an SSR that has a bypass switch to allow the system to boot then an M80 command in the config.g keeps the power on. Before my Duet2 died this would be a quick button press but currently I need to hold power for 30s before the Pi boots. I had a config.g file on the SD card that only had an M80 and it is virtually instantaneous but then the Duet doesn't enter SBC mode.
      I saw DC42 is working on allowing a panel due to switch between standalone/SBC modes which I hope will also allow a config.g to do it too.
      Otherwise I'll have to wire in a USB adapter for +5v and make the printer "always" on.
