    DWC update - How to?
    Duet Web Control
    • felt342undefined
      felt342
      Can somebody please show the latest repository of Duet web control and how to install it? Been searching clean page with versions and how to update - have no luck or blind ::)
      I found this one - https://github.com/Duet3D/DuetWebControl/tree/3.1.1 is that correct? Then I upload in here and I got a bunch of files in the System editor tab.
      Definitely I am doing something wrong 🙂
      Industrial 3D printing service in the Netherlands - gagatstudio.com
      • A Former User?
        A Former User
        try this https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
        upload zip file as is if you want 3.1.1
        • felt342undefined
          felt342
          Hi @bearer
          I did upload using "Upload file" button in the General tab. But my interface didn't change at all. I am printing at same time, might it affect?
            You are also using firmware 2.02. You'll need to update your firmware as well for compatibility with 3.1.1.
            If you intend to stay with RRF2 you should update to 2.05.1 by uploading this zip file: https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/Duet2Firmware-2.05.1.zip
            That should get you DWC 2.0.7.
            • felt342undefined
              felt342
              Thanks, that's works!
