Dual Extruder Config Setup Help Needed
I'm coming over from a different type of controller and have a single extruder printer working very well.
I'm having trouble with my config files I believe for a dual extruder setup/
My current config.g file is listed below along with the other need files to supposedly activate 2 extruders.
My panel due shows the heat bed reaching temperature and the first extruder should be heating to 228C but after less than a minute the extruder reaches a much lower temperature and starts to print before the correct temperature is reached. Meaning my printer starts printing at around 50C causing me to stop the printer.Also on a side note the "active" bed temperature never shows on the screen even though the heater is working.
The standby bed temperature shows -273C until the active temperature is reached at which point everything reads correctly.
I may have read somewhere this is normal but can someone verify this?Anyone care to assist?????
"Config.g" File
; Prologue and comms section
M111 S0 ; Debug off
M550 3D Printer ; Machine name (can be anything you like)
M551 Preprap ; Machine password;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
M552 S1 ; Enable WiFi
M555 P2 ; Set output to look like MarlinM555 P2 ; Set output to look like Marlin
M575 P1 B57600 S1 ; Comms parameters for PanelDue; Movement section
M569 P0 S0 ; Drive 0 (X) goes forwards (change to S0 to reverse it)
M569 P1 S1 ; Drive 1 (Y) goes forwards
M569 P2 S1 ; Drive 2 (Z) goes forwards
M569 P3 S1 ; Drive 3 (E0) goes forwards
M569 P4 S1 ; Drive 4 (E1) goes forwards
M574 X1 Y1 Z1 S1 ; set endstop configuration (X and Y endstops only, at low end, active high)
M350 X16 Y16 Z16 E16:16 ; Micro-Stepping Setting
M906 X1500 Y1500 Z1500 E1000 ; Set motor currents (mA)
M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2)
M203 X10000 Y10000 Z800 E3600 ; Maximum speeds (mm/min)
M566 X200 Y200 Z20 E20 ; Max Jerk speeds mm/minute
M208 X302 Y275 Z250 ; set axis maxima (adjust to suit your machine)
M208 X0 Y0 Z-0.2 S1 ; set axis minimum (adjust to make X=0 and Y=0 the edge of the bed)
M92 X81 Y81 Z402 ; Set axis steps/mm
M92 E1278:1278 ; Set extruder steps per mm
G21 ; Work in millimetres
M83 ; ...but relative extruder moves; Z probe section
; M558 P1 X0 Y0 Z1 H3 F200 T5000 ; Smart IR Z probe, used for homing Z axis, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min
; G31 X11.0 Y0.5 Z1.20 P500 ; Set the probe height and threshold (put your own values here); Heater and thermistor section
;*** If you have a Duet board with 1K thermistor series resistors, change R4700 to R1000 to the following M305 commands
M305 P0 T100000 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 T100000 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
M305 P2 T100000 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
M301 H1 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 0
M301 H2 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 1
M570 S120 ; Increase to allow extra heating time if needed; Tool definition section
M563 P0 D0 H1 ; Define tool 0 to use extruder drive 0 and heater 1
G10 P0 S0 R0 X-6 Y0 ; Set tool 0 operating and standby temperatures
;*** If you have a dual-nozzle build, un-comment the following 2 lines
M563 P1 D1 H2 ; Define tool 1
G10 P1 S0 R0 X6 Y0 ; Set tool 1 operating and standby temperatures; Bed probe section (not needed if you use a bed.g file)
;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of your Z probe
;M557 P0 X60 Y0 ; Four...
;M557 P1 X60 Y165 ; ...probe points...
;M557 P2 X200 Y165 ; ...for bed...
;M557 P3 X200 Y0 ; ...levelling
;M557 P4 X141 Y82.5 ; 5th probe point for levelling (un-comment this to get a 5th point at the centre of the bed); Epilogue
;*** If you are using axis compensation, put the figures in the following command
M556 S78 X0 Y0 Z0 ; Axis compensation here
T0 ; select first hot endThe config files as note below, currently Tool 0 and Tool 1 are both the same other than tool offsets.
tfree0.g; Put G/M Codes in here to run when Tool 0 is freed
M83 ; relative extruder mode
G1 E-4 F2500 ; retract 4mm
M116 P0
tpre0.g; Put G/M Codes in here to run when Tool 0 is about to be activated
G1 X0 Y0 F6000 ; move the head away from the print
M116 P0
tpost0.g
; Put G/M Codes in here to run after Tool 0 is activated
M116 P0 ; wait for tool 0 only to reach operating temperature
G1 E4 F2500 ; undo retraction -
I suspect the problem lies in the start gcode in the file you are trying to print. Please post the first ~100 lines.
Here are about the first 100 lines.
G90
M82
M106 S0
M140 S100
M190 S100
M104 S220 T0
M104 S220 T1
M109 S220 T0
M109 S220 T1
G1 T0 E8
G1 T1 E8
G28 ; home all axes
G92 E0
G1 E-5.0000 F6000
G1 Z0.100 F900
; layer 1, Z = 0.1
T0
; tool H0.100 W0.480
; skirt
G1 X156.022 Y71.643 F4800
G1 E-0.8000 F1800
G92 E0
G1 X163.973 Y63.693 E0.2323 F2700
G1 X166.707 Y62.560 E0.2934
G1 X194.334 Y62.560 E0.8642
G1 X197.069 Y63.693 E0.9253
G1 X205.020 Y71.643 E1.1576
G1 X206.152 Y74.378 E1.2187
G1 X206.152 Y190.622 E3.6201
G1 X205.020 Y193.357 E3.6813
G1 X197.069 Y201.307 E3.9136
G1 X194.334 Y202.440 E3.9747
G1 X157.650 Y202.440 E4.7326
G1 X154.915 Y201.307 E4.7937
G1 X146.964 Y193.357 E5.0260
G1 X145.832 Y190.622 E5.0871
G1 X145.832 Y171.878 E5.4743
G1 X146.964 Y169.143 E5.5355
G1 X148.123 Y167.985 E5.5693
G1 X148.123 Y162.128 E5.6903
G1 X149.256 Y159.393 E5.7515
G1 X149.690 Y158.959 E5.7642
G1 X149.690 Y152.378 E5.9001
G1 X150.823 Y149.643 E5.9613
G1 X150.845 Y149.621 E5.9619
G1 X150.845 Y142.628 E6.1064
G1 X151.744 Y140.459 E6.1549
G1 X151.744 Y132.878 E6.3115
G1 X152.472 Y131.119 E6.3508
G1 X152.472 Y123.128 E6.5159
G1 X153.084 Y121.652 E6.5489
G1 X153.084 Y113.378 E6.7198
G1 X153.611 Y112.104 E6.7483
G1 X153.611 Y103.628 E6.9234
G1 X154.078 Y102.501 E6.9486
G1 X154.078 Y93.878 E7.1268
G1 X154.500 Y92.859 E7.1495
G1 X154.500 Y84.128 E7.3299
G1 X154.889 Y83.189 E7.3509
G1 X154.889 Y74.378 E7.5329
G1 X156.022 Y71.643 E7.5941
G92 E0
G1 E-8.0000 F6600
T1
; skirt
G1 X156.429 Y71.915 F4800
G92 E0
G1 X164.244 Y64.100 E0.2283 F2700
G1 X166.803 Y63.040 E0.2855
G1 X194.239 Y63.040 E0.8523
G1 X196.797 Y64.100 E0.9095
G1 X204.613 Y71.915 E1.1379
G1 X205.672 Y74.473 E1.1951
G1 X205.672 Y190.527 E3.5925
G1 X204.613 Y193.085 E3.6497
G1 X196.797 Y200.900 E3.8781
G1 X194.239 Y201.960 E3.9353
G1 X157.745 Y201.960 E4.6892
G1 X155.187 Y200.900 E4.7464
G1 X147.371 Y193.085 E4.9747
G1 X146.312 Y190.527 E5.0319
G1 X146.312 Y171.973 E5.4152
G1 X147.371 Y169.415 E5.4724
G1 X148.603 Y168.184 E5.5084
G1 X148.603 Y162.223 E5.6315
G1 X149.663 Y159.665 E5.6887
G1 X150.170 Y159.158 E5.7035
G1 X150.170 Y152.473 E5.8416
G1 X151.230 Y149.915 E5.8988
G1 X151.325 Y149.820 E5.9016
G1 X151.325 Y142.723 E6.0482
G1 X152.224 Y140.555 E6.0967
G1 X152.224 Y132.973 E6.2533
G1 X152.952 Y131.214 E6.2926
G1 X152.952 Y123.223 E6.4577
G1 X153.564 Y121.748 E6.4907
G1 X153.564 Y113.473 E6.6616
G1 X154.091 Y112.199 E6.6901
G1 X154.091 Y103.723 E6.8652
G1 X154.558 Y102.596 E6.8904
G1 X154.558 Y93.973 E7.0686
G1 X154.980 Y92.955 E7.0913
G1 X154.980 Y84.223 E7.2717
G1 X155.369 Y83.284 E7.2927
G1 X155.369 Y74.473 E7.4747
G1 X156.429 Y71.915 E7.5319
G92 E0
G1 E-8.0000 F6600
T0
; skirt
G1 X156.836 Y72.187 F4800
G1 E0.0000 F6600
G92 E0
G1 X164.516 Y64.507 E0.2244 F2700
G1 X166.898 Y63.520 E0.2776
G1 X194.143 Y63.520 E0.8405 -
Anyone able to spot a problem as per above?
Hi Pete, yes I think the problem is in the gcode at the start of the file. There are commands to set the tool temperatures but no commands to select tools until the first T0 command. Also it has commands like G1 T0 E8 but I have never seen a T parameter used on a G1 command before or documented anywhere.
You should aim for your start gcode to look something like this:
M106 S0
M140 S100
M190 S100
G10 T0 S220 R170 ; set tool 0 active and standby temperatures
G10 T1 S220 R170 ; set tool 1 active and standby temperatures
T0 ; select tool 0
G1 E8 ; prime tool 0
T1
G1 E8
T0I have chosen a standby temperature of 170C in the above but you may want to adjust that.
Also, we recommend to select relative extruder coordinates if your slicer supports it.HTH David
