SOLVED "myprinter.local/" malfunctioning
I have been continuing on with "Getting Started" with the Duet 2 Wifi I am stuck in part 3 step 7 (https://duet3d.dozuki.com/Guide/3.)+Configuration+(General+Cartesian)/10?lang=en)
Note: If you changed the machine name in the RepRapFirmware Configurator, this will be reflected in the .local address. For instance, if you named the machine "My Printer", you will navigate to myprinter.local/ (without spaces and not case sensitive).
Sine the printer name was "Hypercube Evolution", I tried http://hypercubeevolution.local but it is not loading... for some reason.
Try a name without a space?
@Phaedrux
Thanks, it works now.
