    Robotic kinematics
    MultiAxis Printing
    22
    389
    48.3k
    • JoergS5undefined
      JoergS5 @o_lampe
      @o_lampe DH configuration and screw configuration parameters are similar, so I want to store it only one time in RRF, because RRF is limited by memory.
      Screw theory as such has advantages compard to calculations based on DH:
      • closed form calculation of inverse kinematics, i. e. no iterations and all 8 (16) robot solutions
      • no usage of Euler angles, which have singularities like gimbal lock from local calculations. Screw calculates globally.
      And to answer your question: I want to support DH, because it was the standard method for industrial robots, so some users may be used to it. For me it offers the possibility to double check the algorithms by calculating both ways and comparing the results. The DH code will not be included in RRF, however, to spare memory.
      In RobotViewer, I'll support both input methods and I'm thinking about a simple geometric algebra editor to support a third, visual approach to assemble the robot elements.
      I want to start in RobotViewer with a selection of robot type like 6 axis industrial, 4 axis palletized, 5 axis CNC/Prusa/CoreXY and I like the robot type called Gantry robot (ABB IRB6620LX like with one linear and 5 rotary axes) and add this kinematics. It is mentioned and calculated in the Pardos-Gotor book, because it is valuable to route big parts like a wood door.
      • JoergS5undefined
        JoergS5
        I feel the need today to tell that robot kinematics development is still alive. It takes only some time to learn about geometric algebra... I've created a new documentation page about it at https://docs.duet3d.com/User_manual/Machine_configuration/robot_geometric_algebra with some literature links. Geometric algebra is a great geometric approach, which unifies many different mathematical and physical areas and those areas are under constant development, so there are many things to detect for researchers.
        I want to model the robot kinematics and inverse kinematics with geometric algebra, transform them into easier Paden-Kahan subproblems and implement them in RRF with limited memory.
        I am currently half through the Dorst book, which is IMHO the best book to begin with if one wants to learn about it. Hildenbrand has also a very nice style, but it needs more pre-knowledge. Hestenes and Vince have also a very clear language. I am thankful that all those authors write books without typos, I know other books...
        • JoergS5undefined JoergS5 referenced this topic
        • JoergS5undefined
          JoergS5
          Short update to prove that I'm still alive.
          I'm constantly updating the screw and geometric algebra pages, so if someone wants to follow what I learn and learn with me, please check sometimes what's new. I especially update the literature recommendations often, when I detect an interesting author who pleases me with knowledge or who is didactically good (IMHO).
          While digging deep into the scientific articles about geometric algebra, I detect more and more topics which are interesting for 3D printing/CNC area, e.g.
          • support of cylinder objects (additional to sphere), so intersection and distance is easy to calculate, i. e. collision detection will be possible
          • much research is done to support curvature/surfaces like Bezier, Bspline and similar, and new topics are constantly emerging
          I managed to model PK2 (Paden-Kahan subproblem for inverse kinematics solution for 6 axis robot) in geometric algebra with Gaalop tool, so I'm now implementing it into C++ for MCU compatible speed/memory usage. Some parts are better done with traditional algorithms, some with geometric algebra.
          tomsundefined LexJamesundefined 2 Replies Last reply Reply Quote 2
          • tomsundefined
            toms @JoergS5
            Hey @JoergS5! Glad to hear you're still making progress on this massive task!
            Are you planning on updating your GitHub with the code as you work on it? Or only once you have a complete, working, solution? Either is cool, just curious.
            Looking forward to getting to test out the new IK once it's ready 🦾πŸ₯³
            JoergS5undefined 2 Replies Last reply Reply Quote 0
            • JoergS5undefined
              JoergS5 @toms
              @toms I'll update the github as soon I have a working version, based on the new algorithms. My procedure is to update github only if it is buildable. I will offer some binaries for dedicated Duet hardware also, Mini 5+ for sure, and 6HC/6XD if you/someone needs it.
              My first version will be for 6 axis industrial robots. (configurable for all, but primarily tested for 6 axis robot).
              • JoergS5undefined
                JoergS5 @toms
                @toms BTW I'm currently reading Colapinto (master thesis, thesis, and articles), it's an exceptionally good source of information about geometric algebra - and free. He clarified some of my open questions.
                • wieman01undefined
                  wieman01
                  Hello Joerg,
                  First of all, thank you for your continuing support & effort, this is really impressive work you have accomplished so far. Looking forward to the first final release (although it will probably never be final I reckon)!
                  I was wondering if you had any recommendations as to what robot you would take into consideration that works best with the Duet boards. I am new to this, and I don't really know where to start and particularly what I need to pay attention to.
                  What I am looking for is a robot arm that would allow for a "build volume" (if you can even use that terms in this regard) of approximately 1500x1000x1000mm (1500mm being the maximum height) for 3D-printing. I know there are lots of commercial options out there, but I was wondering what criteria a second-hand robot would have to meet in order work with your code and the Duet 2 (or 3). I don't want to spend 10K plus EUR before I know what I am doing. πŸ™‚
                  Would be great if you could share a few ideas, but I totally understand you're a busy man.
                  Looking forward to hearing from you.
                  wieman01
                  JoergS5undefined tomsundefined 2 Replies Last reply Reply Quote 0
                  • JoergS5undefined
                    JoergS5 @wieman01
                    @wieman01 hello,
                    this is a big robot you're planning to buy (or maybe build?). I have no experience with big robots, so I can only give you some thoughts without guarantee, but maybe on the forum are users with experience.
                    My thoughts are, if it shall be Duet based:
                    • it will use probably servos with high current, so a 6XD board is probably the right choice, with a 3HC extension card for optional more axes for endpoint functionality if necessary
                    • those robots use a lot of energy to operate. It depends on your requirements, but I would personally try to buy a low enery one which is slower or smaller or has less payload capability, but this depends on what you're planning to do with it. For palletizing e.g. the 5 axis robots have counterweights, they should need less energy compared to the 6 axis ones. The palletizing robots use a parallelogram structure for one axis less.
                    wieman01undefined 1 Reply Last reply Reply Quote 1
                    • wieman01undefined
                      wieman01 @JoergS5
                      @JoergS5 said in Robotic kinematics:
                      @wieman01 hello,
                      Hello, @JoergS5,
                      Thank you, that is a starting point.
                      We will be using that robot for 3D-printing. The overall payload it will have to carry won't exceed a few kilograms. So there is no heavy lifting involved.
                      Buying vs. building one myself... that is the question. I will need to see what is available first and then decide. It's tempting through to start designing one from scratch now that you are asking... πŸ™‚
                      wieman01
                      JoergS5undefined 1 Reply Last reply Reply Quote 0
                      • JoergS5undefined
                        JoergS5 @wieman01
                        @wieman01 said in Robotic kinematics:
                        When I restart prototyping again, I'll document it in the forum, and you can decide whether you want to join!
                        For 3D printing, you need higher precision than usual, and the typical 6 axis industrial Kuka robot has too low precision for 3D printing (if I remember correctly, they have around 70 micrometer precision or accuracy). It will be very difficult to achieve the required precision with 1.5 m added arms (maybe impossible). If possible, I expect a parallel arm based printer can achieve it.
                        For your case, a CoreXY or Cartesian will probably be better: high precision, high possible build volume. 5 or 6 axis support can be implemented by combining it with a 3-axis print bed (AC, BC or ABC axis). The TUM (munich university) in Garching has a printer in your desired print volume, I saw them printing clay as well. Here in the forum is a current thread about a high volume printer.
                        Edit: this thread: https://forum.duet3d.com/topic/31228/dr-d-flo-s-big-build
                        • tomsundefined
                          toms @wieman01
                          Hey @wieman01,
                          If you're interested in building your own 6 axis arm, I'd recommend looking into AnninRobotics. Chris Annin has done an awesome job putting together a pretty capable, open source, robot arm. It certainly doesn't meet your reach requirements, and having built one, the backlash is substantial enough that I don't think 3D printing would make sense / be practical (at least with traditional nozzles < 1mm).
                          I have version 4 of his robot arm running on 6 HCL's and a 6XD at the moment. There's more info and videos on my GitHub repo if you're interested.
                          It's not the cheapest build, but it was certainly fun.
                          • dc42undefined dc42 referenced this topic
                          • LexJamesundefined
                            LexJames @JoergS5
                            @JoergS5
                            Hi Joerg, we are building a 5 Axis printer, XYZAC, very close to robot type 'Open5x'. I was happy to see that you already did a huge amount of work to get robot kinematics work on Duet, so I would like to build on your work.
                            I took the sources from v3.5.0-beta.3 and added your 'RobotKinematics' files. With some minor updates I managed to generate a binary. Unfortunately the system crashes (reboot) when I try to set the D parameters. The configuration itself looks ok, but the crash occurs as soon as 'RobotKinematics::getForward' is called. I have the following questions:
                            1 - Did I take the correct set of sources
                            2 - Should robotType='Open5x' work with your code base of December 2022 ?
                            3 - If yes, can you give me some hints how to find out what I do wrong.
                            4 - If no, do you have any advice, what the best starting point is to develop the XYZAC kinematics.
                            Thanks in advance ,
                            Lex James
                            JoergS5undefined LexJamesundefined 2 Replies Last reply Reply Quote 0
                            • JoergS5undefined
                              JoergS5 @LexJames
                              @LexJames the code you reference is based on Denavit-Hartenberg configuration parameters, but I changed to Screw Theory. The reason for the change was, that some positions didn't iterate correctly, so the change is from iteration to closed form (i. e. algorithmic solution).
                              The sources changed. I currently build a CoreXY 5 axis prototype to validate the code and then publish the code on github, together with binaries.
                              Sorry for your waste of time of the old source. I'll delete the repository until the new build, which is based on 3.5.0beta3.
                              • LexJamesundefined
                                LexJames @LexJames
                                @LexJames
                                Thanks for your prompt reply.
                                I will wait for the implementation based on Screw theory. Can you say something about the timing?
                                Can I help to speed things up? I don't have a development environment for Duet but I can test and develop in Windows.
                                Is there an old branch that worked for XYZAC?
                                Thanks again for all your good work.
                                • JoergS5undefined
                                  JoergS5 @LexJames
                                  @LexJames of course it will be great if you can test the build. Developing and testing in Windows is not necessary currently, as I do it myself a lot, unit testing.
                                  It's better to wait for the new build, because in the old ones I've tried different methods and I lost the overview (I tried everything like Euler angles, Euler axis, Jacobian with inverse, random iterations, quaternion slerp). The great thing about geometric algebra is that it integrates and explains them all.
                                  I build the prototype as fast as I can. The build will be soon after.
                                  • LexJamesundefined
                                    LexJames @LexJames
                                    @LexJames
                                    Understand. Sorry to ask again about the timing because we have to decide to build on your generic solution versus building our own kinematics dedicated for our purpose. We prefer the first but do you need days, weeks, months...?
                                    • JoergS5undefined
                                      JoergS5 @LexJames
                                      @LexJames I make a build and post tomorrow morning for a first test.
                                      I check it in and make binaries.
                                      LexJamesundefined 1 Reply Last reply Reply Quote 0
                                      • LexJamesundefined
                                        LexJames @JoergS5
                                        @JoergS5
                                        Great ! I'm using a Duet3HC6 + 5x Duet Expansion 1XD, however if you check-in the source code, I can compile myself. Keep you updated on my findings. Thanks.
                                        • JoergS5undefined
                                          JoergS5 @LexJames
                                          @LexJames I've uploaded to https://github.com/JoergS5/RepRapFirmware_robot
                                          I could not finish my prototype however. I'm out of office until Tuesday, then I can proceed.
                                          In the Readme I explained how to compile, but I compiled a 6HC bin.
                                          If you have and want to try a toolchanger, please set the defaultToolLength and the M position (the end position of the reference angles) explicitly after a tool change. I need a prototype with toolchanger before I can test it. Maybe I should change to this explicit setting anyway. The risk that a tool is changed unrecognized and a tool crash if the new tool is longer than before is high.
                                          • LexJamesundefined
                                            LexJames
                                            Thanks for the super fast response. Next Monday I will give it a try, but also try to understand your solution. I will start simple e.g. two axis and gradually add more axes till the 5 axes + extrusion are running synchronously. I'm especially interested in your generic approach because we will add 2 more axes in future (tilt and rotation of the extruder). Wish you lots of success with your prototype.
                                            JoergS5undefined 1 Reply Last reply Reply Quote 1
