    Very strange behavior (Mr. David pse help)
    • gate546undefined
      gate546
      There are any permanent logs (still present after power off) for to try to understand what's happened to the machine?
      This morning I found a nasty surprise.
      The machine was printing a long job, about 14 hours of printing.
      It was almost at the end of the job, but something must have happened.
      I found the nozzle stuck in the piece, and the duet wifi that was booting continuously.
      All the leds went on and off continuosly, I have turned off and on the power but the problem was still present, only after the third try all goes normal again.
      It's not a power problem supply because it is a professional type and has 30 Amp. and isn't a power line outage because the power line is managed by a UPS.
      The print was long but no more than other prints made only a few hours before.
      What could have be happened?
      The job was launched directky from the SDCard because I have noticed that, after that I am using this firmware version, there are some strange problems with the web interface and so, try to avoiding problems, I prefer to start the print jobs from the touch panel.
      Now I tried to launch a small test print and everything seems to work properly, nothing strange.
      All suggestions and comments are really appreciated.
      Firmware Version: 1.19beta6 (2017-06-10)
      WiFi Server Version: 1.19-beta1
      Web Interface Version: 1.16
      Dommy
        If all the LEDs went off including the blue one, then the power to the Duet kept failing. Possibly causes include:
        • Bad power in connection. Check that the VIN terminal block screws are tight.
        • Something drawing more that 30A shortly after power up. But I would expect you to see signs of charring if anything on the Duet was doing this.
        • A fault in the PSU causing its overload protection to trigger falsely.
        • gate546undefined
          gate546
          @dc42:
          Hello Mr. David,
          Your suggestions are all right, in fact these are the first things I thought and controlled, unfortunately I find nothing unusual and then, as I wrote before, I launched a test print and everything worked well.
          So I guess there's no log, right? If I enable debugging in the firmware what happens?
          Do you completely exclude a possible bug under certain conditions?
          Are you aware of the slight anomalies with the web interface?
          Thank you anyway for support
          Dommy
