UNSOLVED 3DPlatform 3DP1000 Sure Print servo
3DP1000 printer uses TSM23P-2AG stepper with servo both with Marlin (Sure Print upgrade) and Duet (Workbench models). Anyone could help figure out how to connect/configure with Duet?
https://support.3dplatform.com/portal/en/kb/articles/sureprint-servo-upgrade-3dp-1000
You'll want to use this expansion board: https://www.duet3d.com/Expansion_Breakout
makes sure you extend the step timings with M569, 2us should work ok.
you could also just download the config they provide for the newer duet model and adapt it.
@nhof Out of stock
M569 in slicer or in duet config?
duet config.
