homing problems after the upgrade
after the help i got i managed to reach to this
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later + DueX2 FIRMWARE_DATE: 2020-05-19b2
ok i thought this is it but the first thing i noticed is i cant home any axis but they move to any direction i want....
my home x
; homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool on Tue Oct 09 2018 13:27:56 GMT+0300
G91 ; relative positioning
G1 Z5 F1000 S2 ; lift Z relative to current position
G1 S1 X-355 F6000 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F3000 ; go back a few mm
G1 S1 X-355 F360 ; move slowly to X axis endstop once more (second pass)
G1 Z-5 F1000 S2 ; lower Z again
G90 ; absolute positioningand this is what i get when i go homex
Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
Error: Failed to enable endstopsendstops trigger the light on the duet but they are not present in dwc 0 and 1 N/A 2 no
any ideas....
Please post your config.g and all your homing files. Also tell us what type of printer it is, where the end stops are physically located.
Also it looks like you might be trying to update an older style config.g, but if your printer is straightforward you may want to create a fresh config specifically for reprapfirmware 3 with the config tool.
my endstops are xmin y max with a bltouch...
here is the fresh config.g
; generated by RepRapFirmware Configuration Tool v3.1.3 on Fri Jul 10 2020 18:08:18 GMT+0300 (GMT+03:00); General preferences
M550 P"BLV mgn Cube" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P4 S1 ; X on E1
M569 P0 S0 ; Drive 0 goes backwards blv: its was S1
M569 P3 S1 ; Drive 3 goes backwards WAS 0
M584 X4 Y1 Z2 E3 ; Drive mapping
M92 X200.00 Y200.00 Z400.00 E418.00 ; set steps per mm
M566 X600 Y600 Z24 E300 ; Set maximum instantaneous speed changes (Jerk) (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z250.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X320 Y311 Z350 S0 ; set axis maxima; Endstops
M574 X1 S1 P"null" ; configure active-high endstop for low end on X via pin null
M574 Y2 S1 P"null" ; configure active-high endstop for high end on Y via pin null
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
M558 P9 C"zprobe.in+zstop" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P25 X28.5 Y-5 Z0 ; set Z probe trigger value, offset and trigger height
M557 X15:285 Y15:285 S20 ; define mesh grid; Heaters
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
homeall.g
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.1.3 on Fri Jul 10 2020 18:08:21 GMT+0300 (GMT+03:00)
G1 H1 X-355 Y355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-355 ; home X axis
G1 H1 Y355 ; home Y axis
G1 X5 Y-5 F6000 ; go back a few mm
G1 H1 X-355 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y355 ; then move slowly to Y axis endstop
G1 X-13.5 Y20 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning
homex
; homex.g
; generated by RepRapFirmware Configuration Tool v3.1.3 on Fri Jul 10 2020 18:08:22 GMT+0300 (GMT+03:00)
G1 H1 X-355 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G1 H2 Z-5 F6000 ; lower Z again
homey
; homey.g
; called to home the Y axis
G1 H1 Y355 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y-5 F6000 ; go back a few mm
G1 H1 Y355 F360 ; move slowly to Y axis endstop once more (second pass)
homez
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.1.3 on Fri Jul 10 2020 18:08:23 GMT+0300 (GMT+03:00)
G1 X-13.5 Y20 F6000 ; go to first probe point
;G90 ; absolute positioningthe drive section was copy paste from the old one...because one stepper was faulty so i shifted it
the printer is a corexy cubeblvthanks
@kostasbmw said in homing problems after the upgrade:
M557 X15:285 Y15:285 S20 ; define mesh gridQuick look at endstops and probe section tells me that you didnt configure them correctly. Where are you X and Y endstops connected to? Normal way to do this is to connect them to Xstop and Ystop pins, so
M574 X1 S1 P"xstop" and
M574 Y1 S1 P"ystop"
For probe delete +zstop part , assuming your probe is connected to zprobe connection. So that will be M558 P9 C"zprobe.in" H5 F120 T6000
i did the correction to the endstops mannually because in the configurator i have the choice of low and high end and that is what i did....maybe there is something i did nt do
now i home all axis ......
i copied all my previous mumbers to the new config and i m checking the behaviour of the printerthanks for your assistance .....untill the next problem....
