if M552 S1 fails; send M552 S2? Is this possible with RRF3??
@Ben, I suggest that in your script after you find that the state is "changingMode", you delay several seconds, then check it is still 'changing mode" before switching to access point mode.
you could make it run only once or twice by using
if state.upTime < 10 M98 P"WIFICONNECT"
in (untested) theory it will only run the macro in the first 10 seconds after powering on the board. include a G4 and you can guarantee its only ran once.
