connectivity issue- DUET 3 main board 6hc
hi,
im using duet 3 main board (6hc) + duet 3 expansion board for a while,
the setup is a Cartesian printer with multiple tools.
firmware version: RC-12 _3.01
web cotrol: version 3.1.1here is my config file:
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"HH2" ; set printer name ; Network M552 p192.168.200.9 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P4 S0 ; physical drive 4 goes forwards M569 P5 S0 ; physical drive 5 goes forwards M569 P1.0 S1 R1 D2 ; Drive E0 M569 P1.1 S1 R1 D2 ; E1 printhead M569 P1.2 S1 R1 D2 ; E2 printhead M569 P2.0 S1 R1 D3 ; E2 printhead M569 P2.1 S1 R1 D3 ; E2 printhead M584 X0 U1 Y2:3 Z4:5 E1.0:1.1:1.2:2.0:2.1:2.2 ; set drive mapping M350 X16 U16 Y16:16 Z16:16 E4:4:4:4:4:4 I1 ; Configure microstepping with interpolation ; M92 X100 U100 Y80.00 Z462.5 E80:80:75:75:80:100 ; set steps per mm M566 X700 Y1500 Z250 U700 E800:800:800:800:800:800 ; set maximum instantaneous speed changes (mm/min) M203 X15000 U15000 Y15000 Z2000 E10000:10000:20000:15000:15000:15000 ; set maximum speeds (mm/min) M201 X3000 U3000 Y2000 Z300 E500:500:500:500:2000:500 ; set accelerations (mm/s^2) M906 X2000 U2000 Y1500 I10 ; set motor currents (mA) and motor idle factor in per cent M906 E2100:2100:1400:1400:4000:1400 I10 M906 Z2100 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 U0 Y0 Z0 S1 ; set axis minima M208 X550 U550 Y450 Z2000 S0 ; set axis maxima M564 S1 H0 ; Allow axis move without home and outside boundries M206 X-50 Y0 U-50 ;offset axes ; Endstops M574 X1 S1 P"io0.in" ; configure for low end, active-low endstop on X via pin io1.in M574 Y1 S1 P"io1.in" ; configure for high end, active-low endstop on Y via pin io2.in M574 U1 S1 P"io2.in" ; configure for high end, active-low endstop on Y via pin io2.in ; Heaters M140 H-1 ; disable heated bed (overrides default heater mapping) ; Fans ; Tools M563 P0 X0 D4:5 S"F0" ;Define tool 0 M567 P0 E0.5:1 ;MIXING RATIO tool 0 M563 P1 X0 D4:5 S"F1" ;Define tool 1 M567 P1 E1:1.7 ;MIXING RATIO tool 1 M563 P2 X0 D3 S"F2" ;Define tool M563 P3 D1:4 S"F3" ;Define tool M567 P3 E0.5:1.5 ;MIXING RATIO tool 1 M563 P4 X0 D5 S"F4" ;Define tool G10 P0 X-138.0 Y100.0 Z0.0 ;Set tool 0 axis offsets G10 P1 X-144.0 Y0.0 Z0.0 ;Set tool 1 axis offsets G10 P2 X0.0 Y0.0 Z0.0 ;Set tool 1 axis offsets ; Custom settings are not defined
https://forum.duet3d.com/topic/16906/dwc-connection-sd-card-disconnections/4
this thread been created earlier in this topicthe setup works just fine most of the time but sometimes it disconnect and connect again in the middle of printing file.
when it happens the connection is lost and the print file is stopped and the printer need to do homing again.
this cause the print to be sent again and start from starch.
i check my internet connection at the wall socket with different cable and it seems to be fine.
no error messagesis there any reason that the duet doing connection reset in some times?
why is that?
should i do something to improve it?
maybe its a configuration error?will be glad for any help.
thank you
@moo16 said in connectivity issue- DUET 3 main board 6hc:
Please upgrade to firmware 3.1.1 and see of the problem persists.
