    Blobs Happen
    • wannathermal
      wannathermal last edited by
      I am having troubles with blobbing. After printing for an hour or so I get a large blob and if I am not right there to clean it then the xy axis will skip. Any ideas?
      • deckingman
        deckingman last edited by
        That sounds like a build up on the nozzle, which subsequently falls off. What filament? PETG, or at least E3D edge has an affinity for sticking to the nozzle. E3D recommend using a silicone sock to reduce/prevent this. Might be worth a try?
        • burtoogle
          burtoogle last edited by
          If you're using PETG and Cura, turn off combing as that combination can cause blobbing.
          • FrankNPrinter
            FrankNPrinter last edited by
            some slicers have a setting to make the tip go back over the part while doing a retract, this may help prevent the blobs if they are being caused by retracts.
            • deckingman
              @FrankNPrinter:
              In Slic3R it's called "Avoid crossing perimeters" and you are right to point out that it might help.
