Error: Heater 0 fault: 1.6°C/sec is too slow for a heated bed?
  • Apparently, 1.6°C/sec is too slow for a heated bed...
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
    M143 H0 S90 ; set temperature limit for heater 0 to 90C
    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
  • Moderator
    This is usually resolved after running a PID auto tuning and saving the results. Also ensure you are running FW 3.1.1
    https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control#Section_Setting_the_model_parameters_by_auto_tuning
