    How to let steppers move when reaching axis zero
    • jcsb1994
      jcsb1994 last edited by
      I want to ignore the 0.00 position on a given axis and keep going in the negative direction
      As of now, if I press controls to move the axis when they are at 0, they do not move
      I have added this command in my config.g file
      M564 H0
      As I thought it would solve this issue. Any idea? Thanks!
      • deckingman
        deckingman @jcsb1994 last edited by
        @jcsb1994 Once the printer has been homed, the firmware will respect the axis limits and not allow moves beyond them. The reason is that normally those axis limits are also physical limits so respecting them will prevent mechanical collisions.
        To move more negative than zero, you therefore need to define the axis minimum as a negative value using M208 S1 https://duet3d.dozuki.com/Wiki/Gcode#Section_M208_Set_axis_max_travel
        • fcwilt
          fcwilt last edited by Phaedrux
          (M564)
          The H parameter controls movement when homed/not homed.
          The S parameter controls movement within/without min/max limits.
          deckingman 1 Reply Last reply Reply Quote 1
          • deckingman
            deckingman @fcwilt last edited by
            @fcwilt That would work too ☺
