Warning: the height map has a substantial Z offset
7/18/2020, 9:07:34 AM M98 P"0:/macros/PROBE BED GRID"
Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
256 points probed, min error -0.035, max error 0.396, mean 0.189, deviation 0.086
Height map saved to file heightmap.csv
where do i start in fixing this so i dont get this warning and make sure it is using my hieghtmap mesh -
Are you doing a G30 to set the Z=0 datum?
sorry i dont know what that means
@fcwilt said in Warning: the height map has a substantial Z offset:
this is a new thing with my 3D printer worked fine up untill i tried to update it then that didnt go well so i went back to an older version worked fine for awhile then this warning started to pop up
@downshift64 said in Warning: the height map has a substantial Z offset:
Well the warning occurs when the Z offset exceeds a certain amount. So that suggests something has changed as you have used the printer.
The warning mentioned setting the Z=0 datum and that is what a G30 command does.
"G30 ; Probe the bed at the current XY position. When the probe is triggered, set the Z coordinate to the probe trigger height.
"You normally would do a G30 before doing a G29 to probe the bed to create the height map.
You also would do a G30 before doing a G29 S1 command which loads the previously created height map.
What action do you take to create the height map?
i calibrate my z probe height enter that in the config.g file under G31 then probe bed grid it saves the heightmap then thats it iam done
Well include the G30 in the two places I mentioned and see if you get better results.
include it where
; Configuration file for EMW ULTIMATE XL. RTFM! https://duet3d.dozuki.com/
M111 S0 ; Debug off
M550 PULTIMATE XL ; Machine name and Netbios name (can be anything you like, PREFIX WITH CAPITAL P)
M551 Preprap ; Machine password (used for FTP);*** NETWORKING
M552 S1 ; Turn network on
M555 P2 ; Set output to look like Marlin
G21 ; Work in millimetres
M83 ; ...but relative extruder moves; DRIVES
M584 X0 Y1:4 Z2 E3 ; DRIVE MAPPING. EXAMPLE: X0 IS X AXIS MAPPED TO DRIVE 0
M569 P0 S0 ; DRIVE 0 DIRECTION. X AXIS S1 OR S0 FOR DIRECTION
M569 P1 S1 ; DRIVE 1 DIRECTION. Y AXIS M1 S1 OR S0 FOR DIRECTION
M569 P2 S0 ; DRIVE 2 DIRECTION. Z AXIS S1 OR S0 FOR DIRECTION
M569 P3 S1 ; DRIVE 3 DIRECTION. EXTRUDER S1 OR S0 FOR DIRECTION
M569 P4 S1 ; DRIVE 4 DIRECTION. Y AXIS M2 S1 OR S0 FOR DIRECTIONM350 X16 Y16 Z16 E16 I1 ;M350 MICROS STEPPING
M92 X200 Y200 Z400 E409 ;M92 SET STEPS PER MM
M201 X2500 Y2500 Z2500 E2500 ;M201 ACCEL MM/S
M203 X20000 Y20000 Z3500 E5000 ;M203 MAXIMUM SPEEDS MM/M
M566 X700 Y700 Z500 E800 ;M566 JERK MM/S
M906 X1900 Y1600:1600 Z1400 E1100 I30 ;M906 SET MOTOR CURRENT IN mA. I VALUE IS IDLE CURRENT PERCENT
M84 S30 ;M84 MOTOR CURRENT IDLE TIMEOUT IN SECONDS.; AXIS LIMITS
M208 X-27 Y-22 Z-3.0 S1 ; SET MIN TRAVEL
M208 X295 Y295 Z298.85 S0 ; SET MAX TRAVEL. Z MAX VALUE DURING INTIAL CALIBRATION IS TUNED HERE; ENDSTOPS
M574 X1 Y1 S1 ; SET ACTUVE LOW ENDSTOPS
M574 Z2 S1 ; SET ACTIVE HIGH ENDSTOPS; LINEAR ADVANCE
M572 D0 S0.03
; Z PROBE
M557 X0:290 Y0:290 S19.333 ; M557 SET PROBE GRID AND SPACING
M558 P4 F300 H2 I1 T10000 A4 S0.01 R0.8 X0 Y0 Z ; Z probe is presicion touch porbe, normaly openG31 X0 Y0 Z69.92 P5 ; G31 SET Z PROBE OFFSETS. ADJUST THIS Z VALUE PER CALIBRATING PROBE HEIGHT MACRO
; PROBE COMPENSATION TAPER.
;M376 H10 ; TAPER HEIGHT FOR GRID COMPENSATION. SLOWLT TAPER COMPENSTION UP TO SET HEIGHT. ONCE AT HEIGHT COMPENSATION WILL NOT BE IN EFFECT. DISABLED BY DEFAULT (EMW ULXL)
; TEMPERATURE SENSOR PARAMETERS
M305 P0 T100000 B3950 R4700 H0 L0 ; BED SENSOR IS 100K THERMISTOR WITH BETA VALUE OF 3950. DUET WIFI INLINE RESISTOR 4700
M305 P1 T100000 B4725 C0.0000000706 R4700 H0 L0 ; HOT END SENSOR IS 100K THERMISTOR WITH BETA VALUE OF 4725. DUET WIFI INLINE RESISTOR 4700. C VALUE IS COMPENSATION VALUE AT HIGHER TEMPS.; HEATER TUNING PID
; HEATER TUNING PID
M307 H0 A522.8 C1351.1 D19.3 B0 ;H0 IS HEAT BED. AUTOTUNED NOV. 2019 EMW ULXL
M307 H1 A408.1 C196.0 D4.6 B0 ;AUTOTUNED RESULTS STOCK E3D HEMERA;HEATER SAFETY
M143 H0 S105 A1
M143 H1 S305 A1; FANS
M106 P0 S-1 L0.2 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1.0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 H100:101 T35:45 L0.6; Tools
M563 P0 D0 H1 ; Define tool 0
T0; POWER FAILURE RECOVERY. EMW ULXL REQUIRES SEPERATE MODULE TO WORK. PLEASE CONTACT ELITE MACHINE WORKS FOR DETAILS.
M911 S23.5 R23.9 P"M913 X0 Y0 G91 M83 G1 Z3 E-1 F1000"
; Custom settings
M581 E0:1 S0 T1 C1
M581 E0:1 S0 T0 C1; BED HEATER RELAY ACTIVATION WHEN POWERING ON OR REBOOTING PRINTER.
M80 ; TURN BED HEATER RELAY ON
include it where
Well I have a macro that I execute to create the height map so the G30 and G29 go there along with any other commands needed. My macro file doesn't actually look like this as I have included the contents of a few other macros into this code.
; ----- configure z probe ----- M307 H7 A-1 C-1 D-1 ; step 1 - disable E6 heater to enable PWM5 M558 P9 H2 F600 T12000 A5 S0.01 R0.2 ; step 2 - set probe configuration - part 1 G31 X0 Y24.5 Z1.525 P25 ; step 3 - set probe configuration - part 2 M280 P7 S160 ; clear BLTouch alarm (if any) ; ----- set Z=0 datum using probe ---- G29 S2 ; cancel mesh bed compensation M290 R0 S0 ; cancel baby stepping G90 ; absolute moves G1 Z10 F600 ; position on Z for probing G1 X0 Y-25 ; position on XY for probing G30 ; do single probe - sets Z to probe trigger height ; ---- create height map ----- M208 Y-155:145 ; adjust axis min/max values as needed to allow for Z probe offset M557 X-130:130 Y-130:130 S20:20 ; define mesh for G29 G29 ; do probing and create height map file M208 Y-145:145 ; reset axis min/max values G29 S2 ; cancel mesh bed compensation M290 R0 S0 ; cancel baby stepping G1 Z5 F600 ; move nozzle away from bed
I also have a macro for loading the height map. The macro I have for starting a print invokes this file.
Notice here that I am showing the invoking of the macros for configuring the probe and setting the Z=0 datum.
The code that performs these function, that I included the previous post, is essentially what is in these two macros.
M98 P"configprobe.g" ; configure Z probe M98 P"probeZ.g" ; set Z=0 Datum G29 S1 ; load height map M376 H10 ; set bed compensation taper
thank you i will give them a try does it matter where i put these commands in the config.g
i dont use a BLTouch i attach a probe then when i am done take it off and usually dont use it again unless something changes
They should NOT be part of config.g.
If you do like I do and create the height map manually by invoking the macro you would create a macro to do that.
If you wish to create the height map on every print you should invoke the code when starting a print.
As to loading the height map it should be part of the code you invoke when starting a print.
I have my slicer invoke a macro called "print_begin.g". All of the code needed to prepare for printing is in that macro.
Also In this macro I invoke the macro to load the height map.
damn i wish this was easier
Hmm...
Then I don't know how you are going to set the Z=0 datum without a Z probe.
I have found that I needed to install a BLTouch as the Z=0 setting changed as the bed assembly heated up. So each print potentially needed to have Z=0 set again - which is what I do now.
i heat the bed up then probe it and save the height map i have something that uses that each time i start a new print
If you have a Z probe AND make use of macros called via M98 it can be fairly straightforward and easy to maintain.
