Duet Wifi Stepper Driver
  • Hi there
    I got a duet wifi from Fillastruder and it was working fine for months. Suddenly neither one of the stepper drivers are working after about 72 of marathon printing. The steppers are working when I test them with other drivers but the drivers for extruders are not responding. How can I fix this?
    Thanks
    Are you sure that the problem isn't that you don't have a tool selected when you try to extrude, or the tool isn't (or doesn't appear to be) up to temperature and you haven't enabled cold extrusion?
    Is there any sign of burning on the E0 and E1 stepper driver chips? On the rare occasions when they fail, there is usually a burn mark on top of the chip.
    Also, please attempt to extrude using each extruder (so that the drivers are commanded to power up the motors), then run M122 to see what the stepper driver status is.
  • Driver image http://imgur.com/ZRZiTRZ
    M122 Log Dump:
    [[language]]
    Diagnostics
    Used output buffers: 2 of 32 (9 max)
    Platform Diagnostics:
    Memory usage:
    Program static ram used: 13132
    Dynamic ram used: 82380
    Recycled dynamic ram: 2792
    Current stack ram used: 2768
    Maximum stack ram used: 3752
    Never used ram: 29016
    Last reset 00:08:21 ago, cause: software
    Error status: 0
    Bed probe heights: 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000
    Free file entries: 10
    MCU temperature: min 18.9, current 21.1, max 24.2
    Supply voltage: min 12.1, current 12.3, max 12.5, under voltage events: 0, over voltage events: 0
    Slowest main loop (seconds): 0.013824; fastest: 0.000122
    Move Diagnostics:
    MaxReps: 1, StepErrors: 0\. Underruns: 0
    Heat Diagnostics:
    Bed heater = 0, chamber heater = -1
    Heater 1 is on, I-accum = 0.4
    GCodes Diagnostics:
    Move available? no
    Stack pointer: 0 of 5
    macro is idle
    http is ready with "M122"
    telnet is idle
    serial is idle
    aux is idle
    file is idle
    Network Diagnostics:
    WiFiServer is running
    SPI underruns 0, overruns 0
    Webserver Diagnostics:
    HTTP sessions: 1 of 8
  • Neither were responding and I had the tools selected correctly
    Unfortunately you are running an old version of the firmware that doesn't display the driver status. The driver chips do not show any sign of damage. Please try the following:
    • Upgrade firmware to 1.18.2 and re-run the previous test and M122 report.
    • Unload any filament from the extruders, and with the new firmware loaded, send M584 X0:3:4 to make both extruder motors shadow the X axis. Then see whether X movement a!so makes the extruder motors turn.
  • Sorry for the delay. Was away from my printer. Just got the commands sent. I had X on its stepper, E0 on its stepper and Y on the E1 stepper. X and Y seemed to have moved normally but no motion on the E0 extruder.
    Diagnostics ===
    Used output buffers: 1 of 32 (16 max)
    Static ram used: 20320
    Dynamic ram used: 73000
    Recycled dynamic ram: 888
    Stack ram used: 968 current, 2940 maximum
    Never used ram: 33924
    Last reset 00:01:55 ago, cause: software
    Last software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
    Spinning module during software reset: GCodes, available RAM 33576 bytes (slot 1)
    Error status: 0
    MCU temperature: min 24.9, current 25.6, max 26.9
    Supply voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0, over voltage events: 0
    Driver 0: ok
    Driver 1: standstill
    Driver 2: standstill
    Driver 3: open-load-A open-load-B
    Driver 4: ok
    Date/time: 2017-06-26 17:28:56
    Slowest main loop (seconds): 0.005493; fastest: 0.000320
    MaxReps: 1, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 1, completed moves: 0
    Bed compensation in use: none
    Probe change coordinates:
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    === Webserver ===
    HTTP sessions: 2 of 8
  • To eliminate the possibility of a dead stepper I moved the E0 extruder stepper to the x axis and tried it there. It moved nominally.
    Please do the test I asked for in my previous post.
  • Sorry for the incredibly late reply. I haven't been able to work on it for a while. I ran the test and took a video of what happened. That video is linked here.
    In short one of the extruder steppers moves as expected while the other does not want to turn.
