    Difference between DuetPi and DuetPi Lite
    Firmware installation
    • Bluemaluundefined
      Bluemalu
      Give the many permutations available for the build, which is the correct version to use with:-
      Duet3 v3 MB 6HC (v3.1.1 firmware)
      RaspberryPi 4B 4GB
      PanelDue5i (v1.24 firmware)
      What is the definition of the GUI? Is s a PanelDue or a monitor connected to the RPI?
      • A Former User?
        A Former User @Bluemalu
        @Bluemalu said in Difference between DuetPi and DuetPi Lite:
        The lite image only has a console with a shell, the full version has "windows" that boots up with Chrome/DuetWebControl if you have a hdmi screen conncected to the Pi.
        If you don't have a screen connected to the Pi or don't intend to use something to remote login (graphically) or tunnel X over ssh etc you'll be fine with the lite image.
        Bluemaluundefined 1 Reply Last reply Reply Quote 1
        • Bluemaluundefined
          Bluemalu @A Former User
          @bearer - Perfect, what I suspected.
