    Is my Duet wifi board really dead?
    • percybundefined
      percyb
      Hi all,
      Have been running my duet wifi board, updated with RRF3 successfully for a week. then unexpectedly it just stops.
      current status:
      Some LEDS light up, enstop LEDS switch on/off when triggered. Paneldue works but does not show warning messages from config.g file so I assume its not booting to that. Can type gcode into console but no effect.
      No wifi connection to my network.
      Have tried connecting to USB, windows computer can see USB device but says its not working. Correct driver installed and previously worked.
      Tried erasing firmware, no change in symptoms.
      Anything else I should try ?
      Thanks
      • A Former User?
        A Former User
        it'd help to know which LEDs light up.
        also https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        • fcwiltundefined
          fcwilt @percyb
          @percyb said in Is my Duet wifi board really dead?:
          I had a problem recently when updating my second Duet WiFi board from 2.05.1 to 3.1.1. I followed the same procedure that I used for the first Duet WiFi board and that board updated without incident. However the second board went to the phase where is says that the new firmware is installing and that never completed. Ultimately I had to erase the firmware and use the Bossa utility to install 3.1.1.
          But that didn't go smoothly as after the erase and reset of the board no COM port appeared. I reinstalled the USB drivers to no effect. I tried erase and reset again to no effect.
          So I rebooted the computer (Windows 10) and the COM port now appeared, Bossa was able to connect, the firmware was installed and all is now good.
          So when in doubt reboot Windows.
          • A Former User?
            A Former User @fcwilt
            @fcwilt said in Is my Duet wifi board really dead?:
            That should be a t-shirt!
              Sorry.
