    Strange behavior during Print
    • esobreiroundefined
      esobreiro
      I have been facing some strange behaviors with my new setup:
      1-Attempting to extrude with no tool selected
      Occurs occasionally during a print task after a while, often, when I do not restart the board after a finished job.
      The print task continues with no extrusion.
      2-Bad command M408 S0 R1 or M408 S1.
      Occurs during the print but apparently has no impact in the printing job.
      Specifics:
      Board: Duet 2 Maestro (2Maestro)
      Firmware: RepRapFirmware for Duet 2 Maestro 3.1.1 (2020-05-19b2)
      Config File:
      ; Configuration file for Duet Maestro (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Thu Jul 02 2020 14:55:54 GMT-0300 (Horário Padrão de Brasília)
      M550 P"Impressora do Erick" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 P192.168.2.81 S1 ; enable network and set IP address
      M553 P255.0.0.0 ; set netmask
      M554 P192.168.2.85 ; set gateway
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S0 ; disable Telnet
      M569 P2 S1 ; physical drive 2 goes backwards ------------------------------------
      M569 P3 S0 ; physical drive 3 goes forwards
      M92 X80.00 Y80.00 Z400.00 E100.00 ; set steps per mm
      M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) 120 para 300
      M203 X18000.00 Y18000.00 Z180.00 E1000.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X1100 Y1100 Z1100 E1100 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ;M92 X80.00 Y80.00 Z400.00 E442.00 ; Set steps per mm
      ;M566 X1000.00 Y1000.00 Z800.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      ;M203 X18000.00 Y18000.00 Z900.00 E1200.00 ; Set maximum speeds (mm/min)
      ;M201 X3000.00 Y3000.00 Z1000.00 E250.00 ; Set accelerations (mm/s^2)
      ;M906 X1300.00 Y1300.00 Z1300.00 E1300.00 I35 ; Set motor currents (mA) and motor idle factor in per cent
      ;M84 S30 ; Set idle timeout
      M208 X2 Y2 Z0 S1 ; set axis minima
      M208 X328 Y328 Z400 S0 ; set axis maxima
      ;M208 X2:330 Y2:330 Z2:400 ; set axis limits
      ; configure Z-probe endstop for low end
      M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin !xstop
      M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin !ystop
      M574 Z2 S2 ; configure Z-probe endstop for high end on Z
      G28 ; home
      M557 X40:550 Y40:550 S50
      M558 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X10 Y10 Z0 ; set Z probe trigger value, offset and trigger height
      G30 P500 X0 Y0 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
      ;M305 S0 T100000 B3950
      ;M305 S1 T100000 B3950
      ;M307 H0 B0 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit ---B0 teste
      M303 H0 S260 ; auto tune heater 1, default PWM, 240C target or maximum temperature
      M303 ; report the auto-tune status or last result
      M307 H1 B0 S0.5 ; disable bang-bang mode for heater and set PWM limit
      M106 P0 C"Resfriamento" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"fan1" Q250 ; create fan 1 on pin fan1 and set its frequency
      M106 P1 C"Extrusora" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
      Best regards,
      Erick
        You may want to add T0 to the end of your config.g to ensure your first tool is enabled at startup. That may solve some occasions where a tool isn't selected if your slicer doesn't explicitly choose a tool or you don't have a T0 in your slicer start gcode. It doesn't hurt to have it in both places.
        Is your slicer inserting some M408 commands? Not sure why they would be there. If you search the gcode file for M408 are they actually present?
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M408_Report_JSON_style_response
          esobreiro
          Thank you, T0 solve the error!
