no 3.3v on duet wifi
  • I was messing around with mounting a bl touch and plugged it in backwards now the board wont communicate over WiFi or USB and has no 3.3v light i only bought it about a month ago is it possible to get a new one through warranty or am i going to have to fix it myself thanks in advance
  • I suppose that would depend on what caused the board to fail. i.e. warranty will not cover wiring mistakes; ref: https://www.duet3d.com/warranty
    Plugging in backwards sounds like might be on the fix it yourself side of things, but ultimately it is up to the Duet people to call it.
  • thanks for responding i just wanted to check before i attempted a repair. Fortunately my repair worked as i had a few 5v to 3.3v regulators from an attempted repair on a duet maestro.
  • Take care to check the revision (ed: of the duet) and which regulator is used, not all are the same as the maestro.
    All schematics and kicad sources available here if you haven't already found them https://github.com/T3P3/Duet/tree/master/Duet2
    Edit: missread that, but god thing you got it working. I'll still leave the comment for future reference.
