    What are the G Code commands that affect stepper feedrate?
    34
    1.3k
    • jcsb1994undefined
      jcsb1994
      I am trying to send commands that last for a specific period of time, given their feedrate and amount o move, this should be more or less predictable.
      This command:
      G1 H1 X-25.000000 Y-25.000000 Z-25.000000 U-25.000000 F1500.000000
      is supposed to move my motors for about 1 second, but it takes around 1.7s, although the distance of 25mm is respected.
      I have setup my config to convert steps into axis movement correctly since distances are right. But I do not know what can be wrong to have 70% time increase on my expected feedrate!
      here are the commands I think could have an impact:
      M92 X50.929 Y50.929 Z50.929 U50.929  E50.929               ; Set steps per mm
      M566 X100.00 Y100.00 Z100.00 U100.00 E120.00                ; Set maximum instantaneous speed changes (mm/min)
      M203 X10000.00 Y10000.00 Z10000.00 U10000 E10000.00            ; Set maximum speeds (mm/min)
      M201 X1100.00 Y1100.00 Z1100.00 E1100.00                ; Set accelerations (mm/s^2);
      M906 X700.00 Y700.00 Z700.00 U700.00 E500.00           ; Set motor currents (mA)
      M84 S0                                             ; Disable motor idle current reduction
      Thanks for your help...
        Are you taking acceleration and deceleration into account?
        jcsb1994undefined 1 Reply Last reply Reply Quote 0
        • jcsb1994undefined
          jcsb1994 @Phaedrux
          @Phaedrux Yeah! (not in this example however). But even when correcting Feedrate for accel/decel losses (which are pretty small) I have more than 60% increase in time taken (feedrate is basically 2/3 of what is should be on paper)
            There was a question similar to this recently that DC42 had replied to that may explain what's actually going on but I can't seem to find it right now.
            If you looked back through his posts you may find it.
            • jcsb1994undefined
              jcsb1994 @Phaedrux
              @Phaedrux I tried looking at his recent posts, but there are so many!! I didnt have any luck finding something on feedrate bad conversion.
              My program used to work however. I wonder if this can be caused by upgrading to reprap version 3 (I used to be on RRF2 when it worked).
                Phaedrux Moderator @jcsb1994
                @jcsb1994 said in What are the G Code commands that affect stepper feedrate?:
                What was the program? Maybe give some more context on what you are trying to do, how it worked before, and what it does now.
                • jcsb1994undefined
                  jcsb1994 @Phaedrux
                  @Phaedrux I just found out what made the feedrate slow down. It isnt the firmware update, it is the fact that I added motors to my board! It seems like operating 4 motors compared to only 1 drains too much current for the duet3d wifi. Is there a solution to this. As of now (I just tested) with this command:
                  while true
                  	G1 U25 F1500
                  	G1 H1 U-25 F1500
                  M0 H1
                  I get around 1 sec per move (plus wastes from accel/decel)
                  But when I use this command:
                  while true
                  	G1 X25 Y25 Z25 U25 F1500
                  	G1 H1 X-25 Y-25 Z-25 U-25 F1500
                  M0 H1
                  Then I get up to 1.7s per move, as I explained before. It seems linear however, I get a little slower at 2 and 3 motors (around 1.5s per move).
                  Is there a current setting to correct this or it is a physical limit to the Duet3D wifi? I am using
                  for my motor currents, and I my 4 motors are actually
                  • 2 X - 17hd48002h‑22b
                  • 2 X - 17hm15-0904s
                  all of which are nema17. Is there a setting for max board current? I am worried about increasing the max current for my individual motors, the 17hm15 can't/shouldnt go a lot higher.
                  Am I right thinking it is a current issue?
                  Thanks!
                  A Former User? Phaedruxundefined 2 Replies Last reply Reply Quote 0
                  • A Former User?
                    A Former User @jcsb1994
                    i think i would look at the voltage drop in you supply and wiring before putting the blame on the board
                    https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
                    (unless the board is a clone, in which case it likely has 35um copper instead of 70um)
                    edit: playing with highlighting feature of the wiki
                    • jcsb1994undefined
                      jcsb1994 @A Former User
                      @bearer no voltage drop! During movement:
                      It is not a clone, so I am really puzzled right now...
                      • A Former User?
                        A Former User
                        running unto back emf issues them maybe, 12v might not be enough to reach the desired speed? its certainly not a current issue.
                        https://www.reprapfirmware.org/ and emf calculator, there is also a section in the wiki linked above
                          After commanding those movements send M122 and report the results.
                          • jcsb1994undefined
                            jcsb1994 @Phaedrux
                            @Phaedrux
                            I tried increasing the Vin to around 24V but the movements are still slowed. my 24V power supply was pushed to its current limits however (4.8A consumption, and its rated 5A).
                            Here is what I get with M122. Everything looks fine even at 23.5V but the problem persists.
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                            Board ID: 08DGM-917NK-F23T0-6J9DL-3SS6K-KW9SH
                            Used output buffers: 2 of 24 (22 max)
                            Static ram: 27980
                            Dynamic ram: 92936 of which 20 recycled
                            Exception stack ram used: 472
                            Never used ram: 9664
                            Tasks: NETWORK(ready,488) HEAT(blocked,1456) MAIN(running,1824) IDLE(ready,80)
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 00:00:54 ago, cause: power up
                            Last software reset at 2020-07-28 12:22, reason: User, spinning module GCodes, available RAM 9872 bytes (slot 2)
                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                            Error status: 0
                            MCU temperature: min 34.2, current 34.6, max 34.7
                            Supply voltage: min 23.5, current 23.5, max 23.6, under voltage events: 0, over voltage events: 0, power good: yes
                            Driver 0: ok, SG min/max not available
                            Driver 1: ok, SG min/max not available
                            Driver 2: ok, SG min/max not available
                            Driver 3: ok, SG min/max not available
                            Date/time: 2020-07-28 16:13:24
                            Cache data hit count 94461989
                            Slowest loop: 9.87ms; fastest: 0.12ms
                            === Storage ===
                            Free file entries: 9
                            SD card longest read time 0.6ms, write time 0.0ms, max retries 0
                            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 165, MaxWait: 16ms
                            === MainDDARing ===
                            Scheduled moves: 10, completed moves: 10, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                            === AuxDDARing ===
                            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                            Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is ready with "M122" in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Code queue is empty.
                              So you have two different motor types trying to do a coordinated move together?
                              They seem to be quite different motor specs. One rated at 900ma and the other at 1700ma. Setting the current to 700ma for the first would be fine but may be too low for the second.
                              • jcsb1994undefined
                                jcsb1994 @Phaedrux
                                @Phaedrux Ok, so I changed my max current values for 1400mA on the 2 bigger motors. But it didn't change anything.
                                I also had a weird message.
                                I started by uploading this script with the upload and start button
                                echo 12345
                                while true
                                	M122
                                M0 H1
                                And made sure the movements were taking significantly more time than a second each.
                                Then I pressed on pause, and this message appeared:
                                The Printing paused message seems wrong. there isn't even a line ith these values! is the code being changed when uploaded to the Duet3d??
                                • A Former User?
                                  A Former User
                                  you pressed pause and the duet ran pause.g which by default contain some retraction g-code...
                                  • jcsb1994undefined
                                    @bearer Ha ok thanks I understand.. I didn't see it this way I thought it meant where it paused on the running program.
                                    And if a motor current is limited in such a way that it limits its max speed below the required feedrate, will the other motors slow down even if their current max setup will let them reach the required feedrate?
                                      Well there's no way for the firmware to know if back emf or whatever is preventing a motor from behaving as commanded because it's an open loop system, so no, the motion planner shouldn't be slowing down movement because of that.
                                      The reason for asking for the M122 report was to see if there were a number of hiccups being counted, which would be an indication that the internal step rate was being exceeded, which could cause slow down and micro pauses as it tries to keep up. That doesn't look like the case here though.
                                      I'm afraid we'll have to wait until DC42 returns from vacation to be able to really explain what might be going on.
                                      • A Former User?
                                        A Former User
                                        we're also missing the microstepping setting and one motor is 0.9deg and the other 1.8deg?
                                        • jcsb1994undefined
                                          @bearer I have tested with 3 motors of the same model (the one at 1.8deg step) and no luck, the moves still take 1.5s each instead of 1 (1.1 maybe with accel/decel). It doesnt seem like having different motor models change something.
                                          here are my config settings
                                          M350 X16 Y16 Z16 U16 E8 I1                            	; Configure microstepping with interpolation
                                          M92 X101.858 Y50.929 Z101.858 U50.929						; Set steps per mm
                                          And may be all my settings just in case
                                          G91
                                          M584 X0 Y1 Z2 U3 E4
                                          ;M584 A0 B1 U2 V3  				   ; map drives for first band
                                          M564 H0	S0	  				   ; can move motors without homing, S0 can ignore axis limits
                                          M569 P0 S1                                         ; Drive 0 goes forwards
                                          M569 P1 S1                                         ; Drive 1 goes forwards
                                          M569 P2 S1                                         ; Drive 2 goes forwards
                                          M569 P3 S1                                         ; Drive 3 goes forwards
                                          M203 X20000.00 Y20000.00 Z20000.00 U20000.0 E20000.00            ; Set maximum speeds (mm/min) Z wobbles at 800
                                          M201 X1100.00 Y1100.00 Z1100.00 E1100.00                ; Set accelerations (mm/s^2); testing was done at 4500 4500 10 250
                                          M906 X700.00 Y1400.00 Z700.00 U1400.00 E500.00           ; Set motor currents (mA)
                                          M208 A0:63 B0:63 U0:63 V0:63 W0:63 X0:63 Y0:63 Z0:63 E0:63                            ; Set axis min-maxima
                                          G92 X0 Y0 Z0 U0 			; set all position to 0 along axis
                                          ;M574 A1 B1 U1 V1 W1 X1 Y1 Z1 E1:1:1:1 S0          ; Set active low for all 8 motors on Jack
                                          M574 X1 S1 P"!xstop"   ; A min active LOW endstop switch
                                          M574 Y1 S1 P"!ystop"   ; B min active LOW endstop switch
                                          M574 Z1 S1 P"!zstop"   ; U min active LOW endstop switch
                                          M574 U1 S1 P"!e0stop"  ; V max active LOW endstop switch
                                          • jcsb1994undefined
                                            jcsb1994
                                            So I guess there is no other known possible error source? Next step is further research and possible help from @dc42 ?
                                            droftartsundefined jcsb1994undefined 2 Replies Last reply Reply Quote 0
