Automatic Bed Leveling with Conditional Gcode Iterations
Gcode meta commands
6.4k
  • undefined
    Kolbi @fcwilt
    @fcwilt All makes sense. I guess it just goes back to cats, preference to work-flow, and ingrained habit.
    Cheers,
    Kolbi
    undefined 1 Reply Last reply 2 Aug 2020, 01:40 Reply Quote 0
    • undefined
      fcwilt @Kolbi
      @Kolbi said in Automatic Bed Leveling with Conditional Gcode Iterations:
      Cheers,
      Kolbi
      I'm a dog person myself. They don't insist on hiding their location. 😉
      • undefined
        Kolbi
        @fcwilt Me too - that's why I only talk about skinning cats 😂
        • undefined
          Kolbi
          @fcwilt , @Phaedrux , @bearer
          During the day's events, I thought of the above conversations and formulated and blend of both ways (dwc/slicer stop/stop gcodes) to handle filament specific settings. I just made the following setups - all is working very well. It is very basic/generic but will grow from here.
          Let me know any thoughts.
          /sys/start.g:
          ; 0:/sys/start.g
          ; Executed before each print - BEFORE ANY SLICER CODE IS RAN
          ; This also loads the heightmap from the system's set filament type directory
          ; (0:/filaments/XXXX/heightmap.csv), if the heightmap does not exist, it will
          ; create one, and then save in the filament's directory. The HotMesh macro is
          ; a better choice to generate the heightmap as it performs a heat stabilization
          ; routine for ~5 minutes.
          M122 ; Clear diagnostic data to cleanly capture print evolution statistics.
          T0 ; Ensure the tool is selected.
          M280 P0 S160 ; BLTouch, alarm release.
          G4 P100 ; BLTouch, delay for the release command.
          M572 D0 S0.0 ; Clear pressure advance.
          M220 S100 ; Set speed factor back to 100% in case it was changed.
          M221 S100 ; Set extrusion factor back to 100% in case it was changed.
          M290 R0 S0 ; Clear any baby-stepping.
          M106 S0 ; Turn part cooling blower off if it is on.
          M703 ; Execute loaded filament's config.g.
          G28 ; Home all.
          ;G1 Z5 X100 Y100 ; [PINDA] Place nozzle center of the bed, 5mm up.
          G1 Z160 F300 ; [BLTouch] Last chance to check nozzle cleanliness.
          M300 S4000 P100 G4 P200 M300 S4000 P100 ; Give a double beep.
          M116 ; Wait for all temperatures.
          M300 S4000 P100 ; Give a single beep.
          ; [BLTouch] Start countdown - use Z as indicator
          G91 ; [BLTouch] Set to Relative Positioning.
          while iterations <=9 ; [BLTouch] Perform 10 passes.
          G4 S12 ; [BLTouch] Wait 12 seconds.
          G1 Z-15 F300 ; [BLTouch] Move Z 15mm down.
          G90 ; [BLTouch] Set to Absolute Positioning.
          ;G4 S120 ; [PINDA] wait an additional 2 minutes for the bed to stabilize.
          G32 ; Level the gantry.
          G29 S1 [P{"0:/filaments/" ^ move.extruders[0].filament ^ "/heightmap.csv"}] ; Load bed mesh for the system's set filament type.
          if result > 1 ; If the file doesn't exist, perform mesh and save.
          G29 ; Perform mesh now.
          G29 S3 [P{"0:/filaments/" ^ move.extruders[0].filament ^ "/heightmap.csv"}] ; Save heightmap.csv to filament type's directory.
          M400 ; Finish all moves, clear the buffer.
          G90 ; Absolute Positioning.
          M83 ; Extruder relative mode.
          M98 P"0:/sys/current-sense-normal.g" ; Ensure that motor currents and sense are set for printing.
          G1 X0 Y0 F800 ; Final position before slicer's temp is reached and primeline is printed.
          G1 Z2 F300 ; Final position before slicer's temp is reached and primeline is printed.
          ; The primeline macro is executed by the slicer gcode to enable direct printing.
          ; of the primeline at the objects temp and to immediately print the object.
          ; following primeline completion.
          ; Slicer generated gcode takes it away from here.
          /filaments/PETG/config.g
          M300 S1000 P200 G4 P500 M300 S3000 P300 ; play some tones
          M140 S75 ; set bed temp
          M104 S150 ; set extruder warm-up temp
          ; active temp set from slicer gcode
          ; Insert additional filament specific settings here
          ideaMaker Start GCode:
          ; ideaMaker Start G-Code
          ; Layer height={layer_height} ; Pass layer height information to DWC
          ; Set nozzle and bed to the specific temperatures declared within this slicer
          M140 S{temperature_heatbed} ; Set bed temp
          M104 S{temperature_extruder1} ; Set extruder temp
          ; Run macro to print primeline at a 'randomized' Y position from -1.1 to -2.9
          M98 P"0:/sys/primeLine.g" ; Primeline macro
          ; Set pressure advance
          M572 D0 S0.07 ; Set pressure advance
          /sys/primeline.g:
          ; 0:/sys/primeline.g
          ; Print prime-line at a 'randomized' Y position from -1.1 to -2.9
          ; Charge! tune
          G4 S1
          M300 P200 S523.25
          G4 P200
          M300 P200 S659.25
          G4 P200
          M300 P200 S739.99
          G4 P250
          M300 P285 S880.00
          G4 P450
          M300 P285 S880.00
          G4 P285
          M300 P625 S1108.73
          G4 S1
          M400
          G1 X0 Z0.6 Y{-2+(0.1*(floor(10*(cos(sqrt(sensors.analog[0].lastReading * state.upTime))))))} F3000.0;
          G92 E0.0 ; Reset the extrusion distance.
          G1 E8 ; Purge Bubble.
          G1 X60.0 E11.0 F1000.0 ; Intro line part 1.
          G1 X120.0 E16.0 F1000.0 ; Intro line part 2.
          G1 X122.0 F1000.0 ; Wipe 2mm of filament.
          ideaMaker/S3D/PS End GCode:
          ; ideaMaker End G-Code
          M400 ; Make sure all moves are complete
          M0 ; Stop everything and run sys/stop.g
          /sys/stop.g:
          ; 0:/sys/stop.g
          ; Called when M0 (Stop) is run (e.g. when a print from SD card is canceled)
          M83 ; Set extruder to relative mode.
          M106 S255 ; Turn the part cooling fan fully on.
          M220 S100 ; Set the speed factor back to 100% incase it was changed.
          M221 S100 ; Set the extrusion factor back to 100% incase it was changed.
          G1 E-2 ; Retract 2mm of filament.
          M104 S-273 ; Turn off the hotend.
          M140 S-273 ; Turn off the heatbed.
          G1 F1000.0 ; Set feed rate.
          M98 P"current-sense-homing.g" ; Adjust the current and sensitivity for homing routines.
          ; Let cool and wiggle for bit to reduce end stringing
          G91 ; Set to Relative Positioning.
          G1 Z2 F400 ; Move Z axis up 3mm.
          ; Start countdown - use X/Y as indicators of counting
          while iterations <=9 ; Perform 10 passes.
          G4 S6 ; Wait 6 seconds.
          G1 X1 Y1 F1000 ; Wiggle +1mm.
          G1 Z0.5 X-1 Y-1 F1000 ; Wiggle -1mm, Z +0.5.
          G90 ; Set to Absolute Positioning.
          G1 X220 Y205 Z205 F400 ; Place nozzle to the right side, build plate to front, Z at top.
          M107 ; Turn off the part cooling fan.
          M18 YXE ; Unlock the X, Y, and E axis.
          ; Play a triumphant tune to celebrate a successful print.
          G4 S1
          M300 P250 S750
          G4 P251
          M300 P200 S1250
          G4 P201
          M300 P250 S750
          G4 P251
          M300 P200 S1250
          G4 P201
          M300 P250 S2500
          G4 P251
          M300 P150 S2000
          G4 P151
          M300 P150 S2500
          G4 P151
          M300 P350 S3700
          G4 P351
          Simplify3D Start GCode:
          ; Simplify3D Start G-Code
          M140 S[bed0_temperature] ; set bed temp
          M104 S[extruder0_temperature] ; set extruder temp
          M116 ; wait for all temperatures
          ; Run macro to print primeline at a 'randomized' Y positon from -1.1 to -2.9
          M98 P"0:/sys/primeLine.g" ; primeline macro
          M572 D0 S0.07 ; set pressure advance
          PrusaSlicer Start GCode:
          ; PrusaSlicer Start G-Code:
          M140 S[first_layer_bed_temperature] ; set bed temp
          M104 S[first_layer_temperature] ; set extruder temp
          Cheers,
          Kolbi
          • undefined
            fcwilt
            Just FYI you don't need both M140 and M190.
            They both set the temp and activate the heater.
            The difference is that M140 doesn't wait for the temp to be reached whereas M190 does.
            The same applies to M104 and M109.
            There is also M116. From the docs, M116 by itself it does:
            waits for all temperatures and other slowly-changing variables to arrive at their set values.
            undefined 1 Reply Last reply 2 Aug 2020, 20:23 Reply Quote 1
            • undefined
              Phaedrux Moderator @Kolbi
              For some reason, it feels a bit to foreign to me to offload stuff from the slicer's start and end code spots.
              When you use multiple slicers it makes it a lot easier to manage.
              • undefined
                Kolbi @fcwilt
                Thanks @fcwilt! I didn't know I was messing that up. I re-read the gcode documentation on this, I believe the following would be the most efficient.
                M116 ; waits for all temperatures
                undefined 1 Reply Last reply 2 Aug 2020, 20:28 Reply Quote 0
                • undefined
                  fcwilt @Kolbi
                  Yes that should work fine.
                  Now what I and others do is start the heating and then do other things that don't need to wait on the temps, like homing.
                  When all of the "other" things are done then you can use the M116 to wait before proceeding to the next steps.
                  It can save a bit of time.
                  undefined 1 Reply Last reply 2 Aug 2020, 21:18 Reply Quote 2
                  • undefined
                    Kolbi @fcwilt
                    @fcwilt said in Automatic Bed Leveling with Conditional Gcode Iterations:
                    Thanks much! Made changes to above post. 🙂
                    Cheers,
                    Kolbi
                    • undefined
                      Kolbi
                      With all sorted discussed above, I have no actual contents in the following files: tfree0.g, tpost.g, tpre0.g
                      Can I delete these files from the sdcard or will this throw an error?
                      undefined 1 Reply Last reply 3 Aug 2020, 03:54 Reply Quote 0
                      • undefined
                        fcwilt @Kolbi
                        When in doubt you can always rename them while you use your printer to see if an error occurs. Then you can undo the rename if it turns out you need them.
                        When I do that sort of thing I add .HIDE to the end of the name so tfree.g becomes tgree.g.HIDE
                        Now I don't think you need these files - I think that are used when changing from one tool to another.
                        I've never had a printer with more than one tool so I've never had these files.
                        undefined 1 Reply Last reply 3 Aug 2020, 03:55 Reply Quote 1
                        • undefined
                          Kolbi @fcwilt
                          @fcwilt Thanks Frederick!
                          • undefined Phaedrux referenced this topic 10 Jan 2022, 21:53
                          • undefined Phaedrux referenced this topic 1 Feb 2023, 21:55
                          77 out of 79
