    Duet wi fi + duex 5 - drivers faults
    • moo16
      moo16 last edited by
      hi,
      im using duet wi fi + duex5 expansion board for a while,
      the setup is a Cartesian printer with multiple tools.
      firmware version: RC-12 _3.0
      web cotrol: version 3.1.1
      here is my config file:
      ; Configuration file for Duet 0.6 (firmware version 1.21)
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 17 2020 18:15:06 GMT+0200 (Israel Standard Time)
      G21 ; Work in millimetres
      G90 ; Send absolute coordinates
      M568 	; tool mix ratios on
      M302 P1 S0				 ; Allow cold extrusion minimum of 0
      M550 P"A"                        ; Set machine name
      M552 S1                 ; enable network and acquire dynamic address via DHCP
      M587 S"*****" P"******"                ; Configure access point. You can delete this line once connected
      M586 P0 S1                                   ; Enable HTTP
      M586 P1 S0                                   ; Disable FTP
      M586 P2 S0                                   ; Disable Telnet
      M208 X0 Y0 Z0 S1	; Set axis minima
      M208 X300 Y500 Z400         ; Set axis maxima
      M564 S0 H0						; Allow axis move without home and outside boundries
      ;	Drives
      M569 P0 S1                       ; AXIS X
      M569 P1 S1                       ; AXIS Y
      M569 P2 S1                       ; Z LAFT
      M569 P3 S1                       ; FEEDER
      M569 P4 S1                       ; Z RIGHT
      M569 P5 S1                     ; printhead
      M569 P6 S0 		       		 ; FEEDER
      M569 P7 S0                     ; printhead
      M569 P8 S1                     ; printhead
      M584 X0 Y1 Z2:4 E3:5:6:7:8      ;  Use E1 for Z axis
      M350 X32 Y32 Z16:16 E16:16:16:16:16 I1                      ; Configure microstepping with interpolation
      M92 X157.63 Y158.96 Z400:400 E115:320:115:305:320                    ; Set steps per mm for extruders
      M566 X1200 Y700 Z24:24 E800:800:800:800:800                       ; Set maximum instantaneous speed changes (mm/min)
      M203 X30000 Y30000 Z600:600 E15000:15000:15000:15000:15000                 ; Set maximum speeds (mm/min)
      M201 X500 Y400 Z100:100 E600:600:600:600:600                     ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800:800 E2500:1200:2500:1050:1200 I30                  ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                ; Set idle timeout
      ף
      M574 Y S1 P"ystop"   ; Y min active high endstop switch
      M574 X2 S1 P"xstop"   ; X min active high endstop switch
      ;M574 Z1 S1 P"zstop"   ; Z min active high endstop switch
      M563 P0 D0:1 S"A"                 ;Define tool 0
      M563 P1 D2:3 S"B"			    ;Define tool 1
      M563 P2 D0:1 S"C"			    ;Define tool 2
      M563 P3 D0:2 S"D"			    ;Define tool 3
      M563 P4 D4 S"E"			    ;Define tool 4
      M563 P5 D0:1 S"F"			    ;Define tool 5
      M563 P6 D0:1:3:4 S"G"			    ;Define tool 6
      M563 P7 D1 S"H"			    ;Define tool 2
      M567 P0 E3:1				    ;MIXING RATIO tool 0
      M567 P1 E1.5:3			    ;MIXING RATIO tool 1
      M567 P2 E1.5:3			    ;MIXING RATIO tool 2
      M567 P3 E1:1			    ;MIXING RATIO tool 3
      M567 P5 E0.4:1			    ;MIXING RATIO tool 5
      M567 P6 E1.5:3:3:3			    ;MIXING RATIO tool 6
      ;M567 P7 E1.5:3			    ;MIXING RATIO tool 7
      G10 P0                                ;Set tool 0 axis offsets
      G10 P1 X-207.5 Y5                            ;Set tool 1 axis offsets
      G10 P2 X-33 Y6                            ;Set tool 2 axis offsets
      G10 P4 X-108 y-16                            ;Set tool 4 axis offsets
      ;M308 S0 P"spi.cs0" Y"rtdmax31865" A"temp1"		;
      ;M308 S1 P"spi.cs1" Y"rtdmax31865" A"temp2"		;
      ;M308 S2 P"spi.cs2" Y"rtdmax31865" A"temp3"		;
      M558 P0 H5 F120 T6000                        ; Disable Z probe but set dive height, probe speed and travel speed
      ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ;m605 s1;
      M915 R0 ; stall detection
      i started to get warnings about some drivers
      " short to ground"
      "phase disconnected"
      nothing was changed in hardware system and config file wasnt changed but still after a while some drivers became fault.
      board supplier: E3D
      and date of purchase: 2020-06-03
      is there a way to fix those warnings.
      part of the driver already not working.
      is it happen to someone before?
      what should i do? contact supplier?
      tnx
        What exactly leads to an error message coming up?
        What is the exact error message?
        M84 S30
        In this block you have 2 values defined for the Z axis. This is not supported. For each of those cases remove the second value for Z.
        Z400:400 should just be Z400.
        @moo16 said in Duet wi fi + duex 5 - drivers faults:
        Please update your firmware as well. First upload this zip file as is for 3.0 to the /sys folder in DWC and then again for 3.1.1.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
        Once you have those things fixed, please post the results of M122
        s
