Fan1 don't works after update to FW3.1.1
As I had commented in previous post, after updating to Firmware 3.x, one of the fans, the one connected to the FAN1 shocket has stopped working ...
At first I thought it was the fan, after configuring all the fans (FAN0, FAN1 and FAN2) as layer, to be able to control them in DWC, I was able to verify that it was not the fan ... Like, connecting it from FAN1 to FAN0 ....
The last test I have done has been with a multimeter, measuring the output voltage in the Shocks of the fans, and ...
- In FAN0 and FAN2, the voltage was 24.50
but - On FAN2, the voltage was 20.80 ... I guess insufficient to spin the fan
My current configuration of the fans, to do these tests is:
; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 C"Capa Izq" S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 C"Central" S0 H-1 ; set fan 1 value. Thermostatic control is turned on-- M106 P1 S1 H1 M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P2 C"Capa Der" S0 H-1 ; set fan 2 value. Thermostatic control is turned off
-what can i do?
-because it can be? if before upgrading to FW3.x it worked - In FAN0 and FAN2, the voltage was 24.50
