    Dual Y and Z steppers, etc - will this be doable in the future
    • fcwiltundefined
      fcwilt
      I posted an earlier question related to this but it was incomplete. Hopefully I've covered all the issues this time.
      I am looking at a printer that would require 5 stepper motor drivers for the single X, dual Y and dual Z stepper motors AND 5 stepper motor drivers for the 5 extruder stepper motors.
      It would seem that it will also need dual Y and dual Z end stop switches.
      I look at the discussion on dual Z end stop switches but it seemed (I may be wrong) that it required a unused stepper motor output.
      Any hope (now or in the future) of using a Duet setup on this printer?
      Thanks much.
        Dual Z endstop switches require one driver per Z motor, instead of connecting the two Z motors in series drive from a single driver.
        In a previous post I advised mapping the additional homing axes to an unused driver when not homing. But this is just a precaution against sending a G1 command with a U parameter, so it's not essential. If it helps, I'll allow a dummy driver number (e.g. -1) to be specified in the M584 command in future, for when you want to disable an axis.
        Your total motor count is 10, which is the number supported by a Duet WiFi/Duet Ethernet + DueX5.
        • fcwiltundefined
          fcwilt
          @dc42:
          Do you foresee a time when the firmware supports dual end stops in a straightforward manner that doesn't use the somewhat confusing (to me anyway) approach you listed in the other thread?
          Thanks.
            Yes, however it's a low priority compared to other features that can't yet be configured in the existing firmware.
            • fcwiltundefined
              fcwilt
              @dc42:
              That makes perfect sense. I will just have to study the current approach and see if I can wrap my head around it.
              Thanks much.
