    Duet 3 - Invert Reset Pins
    • Gerrardundefined
      Gerrard
      I'm installing a latching e-stop on my machine, and I've plugged it into the two reset pins, but it turns out the operation is inverted - the contacts of the switch are NC, but the board needs NO... Is there a configurable way to invert the board, so it accepts NC?
      Cheers
        You can invert the pin by prefixing the pin name in M950 with an !.
        https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names
        • Gerrardundefined
          Gerrard
          What's the pin name for the reset pins? I can't see it listed here:
          https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_Num_3
          Any suggestions?
          • A Former User?
            A Former User
            @Gerrard said in Duet 3 - Invert Reset Pins:
            Doesn't have one, its a hardware reset pin directly to the microcontroller.
