Heater fault upgrading to fw 3.11
I have upgraded from FW 2.05 to 3.11
I used the on line config tool.
When doing my hotend and bed I was not really sure what to put but getting error 2000cMy heater config in config.g is
M308 S0 P"e1temp" Y"pt1000" R4700 ; configure sensor 0 as PT1000 on pin e1temp
M950 H0 C"e1heat" T0 ; create bed heater output on e1heat and map it to sensor 0
M308 S1 P"spi.cs1" Y"thermocouple-max31855" ; configure sensor 1 as thermocouple via CS pin spi.cs1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limitIts a smart effector with PT100 sensor. I'm using a PT100 daugher board heater is on E0.
and stock Anycubic Kossel plus bed. Also should I use bang bang or pid?
Not sure what I have done wrong here?Cheers.
All good just copied my config for heaters from another machine. All working as it should.
