    DWC does not update Height Map
    Duet Web Control
    • comobileoutfittersundefined
      comobileoutfitters
      DWC 2 will not update the Height Map on screen unless I restart DWC. This seems to be new. I was upgrading hot end/extruder parts and off line for a month or so and things seem to have changed suddenly.
      When I left off, to update the Map on screen I believe I would hit the Height Map button and it would refresh. It is not auto-updating either if that is what is supposed to happen now.
      Thanks!
        It would help to know what firmware version and DWC version you are using.
        It should be either FW 2.05.1 and DWC 2.0.7 for RRF2, or FW 3.1.1 and DWC 3.1.1 for RRF3.
        comobileoutfittersundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          comobileoutfitters @Phaedrux
          @Phaedrux
          Hi - my apologies for the slow reply...
          DWC is 2.0.4
          Duet is 2.03
          Hope this helps...
            Phaedrux Moderator @Phaedrux
            @Phaedrux said in DWC does not update Height Map:
            @comobileoutfitters Try updating to this combo.
            Basically just upload this zip file as is to the /sys folder in DWC.
