Rise/low 1,7 of temperature change....
  • Hi,
    after upgrading my Duet v2 to Fw 3.x... i am having to calibrate bed temperature....
    But, after calibrate, i have an error, with this message in console:
    Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7°C/sec
    There is form to rise/low this limit....? the bed temperature rises, but slow...
  • think i have solved...
    although after doing the temperature calibration, he entered the gcode M500 in the console so that it was recorded in the config.g .... he did not. So manually, I have edited the config-override and copied / pasted the bed line to config.g.
    Now it seems to work
    The config-override,g file is only used if you have M501 at or near the end of config.g. Many users prefer not to use config-override.g.
