Show babystep controls when not printing.
Is there a way to tune babystep before print starts?
I can only do it on DWC. It would be much easier to use Paneldue.Thank you!
Well the intention is to live adjust while the first layer is going down, so it's only active as a button on the print view. If you still wanted to adjust it outside of that, you could create a set of macros to do the adjustments and execute them from the macros view.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M290_Baby_stepping
Is there any downside to always show the tune babystep button on Paneldue?
If not, why do we purposely restrict that?
Paneldue shows current babystep while I’m tuning it, making it much easier to use than macro.
If you add a single M290 on the line after your adjustment it will echo back the current value.
M290 R0.1 ; increase baby stepping by 0.1
M290 ; echo current baby stepping amount
